help with a program
Hi im new here and I just started learing basic
im have trouble with a photoresistors sensor program
i built a solar panel i figured i try putting it to a servo
motor and a photoresistors senor so the panel could
follow the light and stop when the sun goes down
also is there any to have the boe-bot shut down at a given time
2) Develop your project in pieces. Get the photoresistors working the way you want. Good references include the Basic Stamp Syntax and Reference Manual and the What's a Microcontroller? tutorial. Separately get the servos to move the way you want, then combine the two pieces.
3) When asking a question, try to make it as specific as possible. Also include a schematic of your setup and a copy of your code (as an attachment to a message, not cut and pasted into a message ... that often loses useful formatting and sometimes the forum software gobbles some items in square brackets.
