Looking for information on longevity of servos
BradC
G'day All,
As part of the automation of my ancient iron chariot, I've replaced the heater valve with a manual one controlled by a tiny 9g model aircraft servo (controlled by a Propeller).
At first I had trouble with the servo buzzing at various setpoints, but I've fixed that by driving it about .002mS past the desired point and dropping it back. I now get dead accurate positioning with no apparent complaints from the servo.
I just wonder how long this contraption is likely to last in an environment where it is called upon to make periodic adjustments to the valve while the vehicle is running.
Has anyone used cheap(ish) servos in long term environments? How do they last?
Release the hounds!
Release the hounds!
How long will yours last? Much depends on the context. Is it an extreme environment? Are you loading the servo excessively. Nobody can tell you for sure.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Aside from it being noticeably slower than a modern standard servo, it is still working just fine and is quieter than most.
Rich H
p.s. Karbonite is another material that servo gears are made out of.
Post Edited (W9GFO) : 7/11/2009 4:47:43 PM GMT
Due to R/C models being propelled by nitro fuel, the servos are somewhat resistant to chemicals and heat. But they are mostly a thermoplastic that might soften and melt at temperature extremes.
As to the original question - I don't know. As long as the servo isn't worked too hard (gear stripping), too often (wear) or isn't being cooked - assuming a descent quality servo - I see no reason for it not to last as long as any other similar car part.
If you want to reduce the chance of failure, if it were me, I would replace the 9g servo with a standard size Futaba or JR servo. Or if standard size is too large, a smaller high torque Futaba or JR. On my multi-thousand dollar aerial photography helicopter I use only Futaba digital servos.
Eeek! That's not true - I use a Parallax (rebranded Futaba) continuos rotation servo (not digital) for the tilt mechanism on the camera.
Rich H
I actually replaced the 9g servo with a genuine Futaba unit yesterday W9GFO. It'll be interesting to see how it lasts. The load is not great, and the movement frequency is anywhere from nothing to once every 10 seconds. As it's operating in bang-bang mode, I'm just rotating it about 60 Degrees to the same points each time.
I was more concerned about the sensor pot wear than the gears to be honest. I'd heard rumours that servos tended to wear excessively when they were jittering as it tears up the track on the pot.
Release the hounds!
