Rocket dataloger testing need a retrievel system
I am into rockets, one thing that i want to do is to make a simple data logger to get a bunch of data that can be graphed out after the flight, one problem... i live where there are a lot of woods, and corn growing in the fields. I dont want to launch $150 worth of sensor up and not be able find it for a few days while it sits outside in the rain and gets destroyed (happens a LOT) i need a simple system to find the rocket, i have thought about using a simple buzer, but if it ends up landing in the woods on the neighbors property it might get annoying(yes we have permission from her to go on her land to retrieve them, she like watching them) and since im makeing this a data logger and all, i would really like it to use some sort of rf, just a simple transmitter or something that would send out a signal that i could have a receiver pick up and display the values. this may sound like an over the top thing but i think it would be a great learning experience. any info and opinions are welcome
How high are you launching? What's your rocket diameter? Do you have enough room for a (Parallax BOE, etc.) board inside your rocket? If you're launching to low altitude, a really loud (120 decibel, etc.) Radio Shack sonic locator ("noise maker) might do the trick. Your next best bet is a GPS tracker inside the rocket, but they get pricey (BigRedBee.com, etc.) You would also need a GPS receiver. Keep all of us rocket scientists posted!
Mark
NAR, TRA
It's also a lot easier to find your rocket when there are a whole bunch of guys flying where you're flying. More eyes on the rocket really help things.
Put a little shark liver oil on your rocket and train your dog to sniff it out.
That's what they used to do at White Sands back in the old days.
I sniff you not:
www.wsmr-history.org/Dogs.htm
That almost certainly will break the FCC rules!
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I am personally planning something like this myself - whenever I am not doing a project for a client... so maybe when I'm 90!
Dave X.
Digi product page for the XBee PRO XSC:
http://www.digi.com/products/wireless/point-multipoint/xbee-pro-xsc.jsp
Post Edited (xanatos) : 7/12/2009 1:48:36 AM GMT
http://forums.parallax.com/showthread.php?p=814170
The material about the XBees starts near the bottom of the first page of the thread, and is mostly found on the following two pages. It does work, even with the shorter-range 2.4GHz models. With the 900 MHz model you should get really good communications, though of course at somewhat greater expense.
I told him if it were me, I would install a GPS system and an SMS device. When the rocket or balloon stopped moving it would dial my cell phone and send me the GPS coordinates. H every much liked the idea and I believe he did implement that since I never heard from him again. Not sure if you have the extra room/power for the additional components.
Parallax Engineering
Chris: Too bad you never hear back from the folks when stuff works!
Dave
Post Edited (xanatos) : 7/12/2009 8:42:12 PM GMT
I hope when you try this out you'll post some reports on how it goes, or at least PM me about it. I'm EXTREMELY interested in using XBees for rocket telemetry (and to keep the Parallax connection, I'm also interested in using Stamps and/or Props to collect the data, as well as on the receiving end to send the information to PLX-DAQ).
I did some more work tonight with my ground station setup - it doesn't seem to be quite able to keep up with the data sent out by the MAWD, and I'm not sure where the issue is. I'm hoping that moving it all to Propeller will make it able to keep up, but that's not going as smoothly so far as I'd hoped.
Paul
Dave
