parallax proto board running at 11.1 volts
i recently received a display that run on 9 to 24 volts. the battery i have outputs 11.1, can the proto board regulators handle this or do i need a seperate regulator from the battery before the proto board. any info is helpful
I happen to have a 12v TV display. Running everything off of one source would be an advantage. So I also might try to epoxy a heat sink to the 5volt regulator.
One could insert a 9v or 7.5v regulator in line to dump the heat if you don't want to mess with the board and adding heat sinks
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Post Edited (Loopy Byteloose) : 7/7/2009 10:49:31 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
The heat in my case is below warning zone, but when I tested the back light on the LCD a strange smell suggested to avoid back light..
