Hacking rc toys
·when hacking a rc toy,at what point on the toy circuit board do you connect to in order to use the homework board. Trying to build a microcontroller to control· a toy car.· most toy rc (small ones) that have 4.5 volt dc motors. Have collected 8 different toy car boards. Most look alike. Suggestions?
You'll have to come up with a schematic for the toy car to try to figure out the RC part unless you just want to sense what voltage is applied to the motor.
Parallax Tutorials: www.parallax.com/tabid/535/Default.aspx
Nuts and Volts Columns: www.parallax.com/Resources/NutsVoltsColumns/tabid/272/Default.aspx
TURN OFF THE CAPSLOCK KEY, IT LOOKS LIKE YOU ARE SHOUTING AT US!
Hopefully, you'll get some answers. RC is not my cuppa tea.
--Rich
If you just want to reuse the mechanical side then one of the things that maybe helpful is to replace the motor. I have used stuff that uses a low voltage (3V) high current motor such as this one http://www.pololu.com/catalog/product/77 . While you can build H-bridge to drive it its a pain to interface to a micro and pre-built H-bridge for that current are expensive. I find its cheaper to replace the motor with http://www.pololu.com/catalog/product/604 . Its the same size as the other motor but takes a higher voltage (6-9V) and lower current so its easier/cheaper to build a H-bridge.
You will have to check if the toy you have uses the right size motor but if they use Tamiya parts then its pretty likely.
