Model Police LED Lights for .3mm and 1.8mm lights
Hello,
Looking to run staedy·head lights and·tail lamps, Wig Wag frontlights, light bar controlled stobes and led display showing differnet patterns. I was wondering if I'm on the right track with the Basic Stamp. I have used leds with a 9 volt and now ready for some more action that I was told could be done with the Stamp 1 or Stamp 2 using a micro contoller. I also have someone in the family that know C++ and is a data base delveoper. Any help with my goal· of lighting a model diecast police car would be great learning experience. Thanks BB
![shakehead.gif](http://forums.parallax.com/images/smilies/shakehead.gif)
You can buy a development board or carrier board to proto type your circuit and code. Build and test one step at a time it will get easier as you go.
Any questions you have or thoughts on what I have said will get answered in this forum . So use the Parallax resources and I have no doubt you will succeed with your project.
Jeff T.
what model would be best for the BS2 with a 9 volt bat. Plus can that be coded with micro contoller. Not sure what you mean by development board or carrier board. Should I just buy the basic kit and learn from the start and build my way to the BS2 model. Here are some links of what I others are doing and I'm trying to get the terms dowm like PCB. And was wondering ifthe BS2 is too big for the car. Thanks for your time Jeff.
...Brian
http://www.parallax.com/tabid/137/List/0/CategoryID/12/Level/a/SortField/0/Default.aspx
The video you provided was pretty much what I imagined it would be. I would think a carrier board would fit check the dimensions, with the carrier board you have to purchase the BS2 as a separate item. Any of the BS2's will do for your project.
The carrier board has a small printed circuit area for soldering components if you wish and also has terminals for a 9v battery.
Heres a link to the various stamp modules
http://www.parallax.com/tabid/134/List/0/CategoryID/9/Level/a/SortField/0/Default.aspx
The modules have a voltage regulator and serial interface built in·, combined with a carrier board they are ready to go (don't forget to download the programming interface (IDE) from the Parallax download page).
Jeff T.
Thanks for looking out for my post. I will work on it this week and send you a reply to see if I'm headed in the rigt direction BB
I stopped development and my program will not do simultaneous lights - for example turn signal· and the red/ blue· flashing "bar".
Just a matter of adding nested timing loops.
Cheers Vaclav
Thanks BB
http://www.efx-tek.com/php/smf/index.php?topic=69.0
cheers, David
