via and current?
What is better for high current situations?
lots of small vias or 1 or 2 big vias?
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Try being pragmatic rather than theoretical. Sometimes that is where the real answer lies.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Leon
http://www.4pcb.com/index.php?load=content&page_id=95
If the added resistance of tin or lead solder were significant, we would all be using silver solder. I'll restate that - Being pragmatic is likely to offer a better solution.
Post Edited (Loopy Byteloose) : 7/6/2009 2:45:17 PM GMT
picky picky ;-P
I think it's only built into Pulsonix (I've only started looking at it a few weeks ago).
Leon?
Leon
It would still be a good idea to calculate it. I don't like trusting to luck.
Leon
Leon how many 12mil vias does your calculator say for 20 amp pulse? Heat not to much an issue no more then 1 pulse an hour.
Assuming that the plating thickness is 0.001" and the board is 1.6 mm thick, I make the resistance of one via to be 0.00136353 ohms. That gives 0.545411 W for that via, at 20A.
If it's a pulse you might need to take account of things like inductance, in which case several small vias would be better than a few large ones.
Leon
Post Edited (Leon) : 7/6/2009 4:39:29 PM GMT
