Quick question on motor selection.
So after blowing up one motor, i'm forced to choose through the box of motors that i have available for replacement.
The standard motors that come with the GM9 (Gear Motor from solarbotics), the resistance measurment taken accross the tabs was 8.5 ohms.
8v/8.5 = 941mA
The question i have is should i take these resistance measurements without the capacitors connected to the leads and case?
1amp is alright with me, but, looking through my other motors (and all my motors have bigger stranded coper wire for windings), and the measurements are comming out at about 1.5 to 2ohms. Well...
8v/2 = 4amps !!! ON ONE MOTOR
Is this the correct formula? Even if i run them at 5v thats still 2.5amps.
Would i be better of buying a few of the standard replacement motors that came with the GM9s? Or is there a way i can up the resistance on these motors?
-Michael Morris
······ I'll try everything once [noparse]:)[/noparse]
8v/8.5 = 941mA
-Michael Morris
-Michael Morris
1. non-load, the motor is generating a voltage that is close to the supplied voltage but in reverse, so the voltage across the motor is the difference of the supplied voltage and the generated voltage. This is the voltage to divide by the motor resistance so the non-load current is small. It increases has more load is taken from the motors (the motors slow down so the generated voltage is lower)
2. Stall, the motor is stopped so it is not generating any voltage, so the current is the supplied voltage/motor resistance.
The above is a simplification but explains the basics of why the stall current is much higher than teh non-load current and why the motor current increases as the motor does more work.
Also the start currents drawn by the motors are very high - higher than voltage/resistance expects because the motors are inductors and they take current to generate their field. You often find that the start current is more than the stall current for very short periods of time, similar for reversing (in fact for reversing, the supplied voltage is in the same direction as the generated voltage so you have 2x voltage across the motors, so 2x stall current, which is why regulators for motors are normally a bad idea)
Also pololu.com sell replacement motors for the solarbotics gearmotors. http://www.pololu.com/catalog/product/604
and upgraded motors http://www.pololu.com/catalog/product/604
they also sell http://www.pololu.com/catalog/product/24 which is a beter version of the l293d
Rich H
At 5 V, the gearbox and motor provide 43 oz-in of torque and 66 RPM, which is faster than a standard RC servo. The free-running current is 74 mA, and the stall current is 670 mA. This motor also comes with a built-in safety clutch.
The 2 motors you have are probably very similar to that so they should be powered from a 5 or 6V supply to reduce the risk of cooking the motors. Even at 5V it is possible to cook the motors if they are stalled for a long period of time.
If you use a 5-6V battery pack and connect the motor/L298 directly to the battery pack NO REGULATOR IS NEEDED FOR THE MOTOR CIRCUIT. The micro and other electronics will need regulators.
