RESOLVED:Counter will not increment.
HARDWARE ISSUE: Pins 0-4 did not make contact in my breadboard so while the waveform was right it never go to the pin.
I have a routine that generates 64 clock pulses (OK) and @ clock pulse 51 I have a L/R circuit that is connected to Pin 1 and I want to count the system clocks until the input drops below 1.65vdc.
The waveform is perfect and exactly what I expect. I created an extra delay at count 51 so it is easy to spot on my scope in the string of clock pulses.
Anyway, I do a MOV PHSA, #0 just before I do a return from #ClockSet then if I am at ScanCnt 51 I add some delay then do a
MOV InputCount, PHSA but the value is always zero. In looking at the scope I expected something like ~~50 or so. but it is always zero.
Just to make sure the Write routine works I have place different values in InputCount and they get written perfectly via the FullDuplex code.
I set the CTR MODE as follows: I think I have this right but perhaps another set of eyes will help
My Initialize routine:
And the main routine:
Post Edited (Wurlitzer) : 7/4/2009 2:32:18 PM GMT
CntrA_Cfg long %0_01000_000_00000000_000000_000_000001 'pos detection pin 1 for APIN
Initialize_I_O
{========= SET PINS TO OUTPUT MODE =======================}
or dira,ClockPin
or dira,DataPin
mov CirQueStartADDR, par
mov CirQueWritePtr, par
mov CirQueEnd, par
add CirQueEnd, #200
mov ctra, CntrA_Cfg 'pos detection pin 0 for Counter A APIN
mov frqa, #1 'a 1 is added every clock cycle when cntr is counting
mov KbMask, #1 'pin 0
mov ScanCnt, #61
Initialize_I_O_Ret ret
entry
call #Initialize_I_O
call #StartNewScan
MainLoop
mov InputCount, #$1ff
call #Clockset 'phsa is set to zero just before the return
cmp ScanCnt, #51 wc,wz,nr
if_ne jmp #skp1
'REMOVE TEST ONLY
mov time,cnt ' REMOVE Current clock loaded into time
add time,on_time ' on_time added to time
waitcnt time,on_time
'END REMOVE
mov InputCount, phsa
tstLoop
call #WriteCircQueue
skp1
mov tmpKBAddr, #KB_ImageArray ' address of 1st dword in KB_Image array
add tmpKBAddr, ScanCnt
movs GetKBImage, tmpKBAddr
nop '
GetKBImage mov tmpKBImage, 0_0 'source address is modified above
{ ' tmpKBImage DWord contains calibration data for 1st and 2nd tch and
on off status for each touch
| 31....16 | 15.......2 | 1....0 |
| 2nd Touch| First Touch| 2nd On/off, 1st On/off |
| Count | Count | |
'determine if current count is greater or less than 1st touch
mov tmp1, tmpKBImage
and tmp1, FirstTouchMask
ror tmp1, #2
cmp tmp1, InputCount wc, wz, nr 'C flag set if tmp1 < Input count
if_b jmp #LessThanFirstTouch
and tmp1, SecondTouchMask
ror tmp1, #16 'Second touch calibration value
if_be jmp #AtFirstTouch 'current count is between first touch threshold and
'below 2nd touch threshold.
AtSecondTouch
AtFirstTouch
LessThanFirstTouch
tmpjmp 'end of Main Loop
call #Clockclear 'NOTE: some time as already expired
djnz ScanCnt, #MainLoop 'loop until all 61 keys are scanned
call #StartNewScan
jmp #MainLoop
ClockSet
mov time,cnt ' Current clock loaded into time
mov t, #0 wz ' all this does is set the zero flag
muxz outa, ClockPin ' Sets Pin high
mov phsa, #0 'set counter to zero
ClockSet_Ret ret
ClockClear
muxnz outa, ClockPin 'sets pin low
ClockClear_Ret ret
StartNewScan 'sets a single HIGH into S/R for scanning the keyboard/s
muxz outa, DataPin
mov ScanCnt, #61
mov WriteAddr, CirQueStartADDR
add WriteAddr, ScanCnt
call #ClockSet
' waitpeq KbMask,KbMask ' Wait for input to rise above 1.5 vdc. 'waitpne KbMask,KbMask
'RESTOR THIS BELOW '
'''''' wrlong phsa, WriteAddr
sub WriteAddr, #1
sub ScanCnt, #1
call #ClockClear
mov t, #0 wz
muxnz outa, DataPin
StartNewScan_ret ret
WriteCircQueue wrlong InputCount, CirQueWritePtr
'add CirQueWritePtr, #4
cmp CirQueWritePtr, CirQueEnd wc,wz,nr
if_nc mov CirQueWritePtr, CirQueStartADDR
WriteCircQueue_ret ret
