converting to ascii — Parallax Forums
converting to ascii
jsestijsesti Posts: 5
edited 2009-07-03 10:52 in Propeller 1
is there a command that allows me to convert a value·to ascii?
thanks
    edited 2009-07-02 16:09
    jsesti,
    Take a look at "Simple_Numbers.spin" located in the directory that you installed the Propeller IDE.
    What you have to do is basically look at each digit and then offset each digit by $30.
    Beau Schwabe
    IC Layout Engineer
  • jazzedjazzed Posts: 11,803
    edited 2009-07-02 16:20
    And if you give him $60 USD, you can get double the values [noparse]:)[/noparse]
    Of course, $30 means hexadecimal 30, binary 110000, or decimal 96 48. (AJM yup, saw too many 0's I guess).
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    Post Edited (jazzed) : 7/2/2009 5:25:13 PM GMT
  • AJMAJM Posts: 171
    edited 2009-07-02 17:12
    decimal 48 rather?
    Hello
    as a global answer to your global question "is there a command that allows me to convert a value to ascii?"
    the global answer is: Yes.
    If I would stop writing here it would be unsatifying.
    The FullDuplexSerial-object and it's derivates FDX+, Extended_FDSerial etc. have a method
    DEC.
    You call this method with a value as parameter and the method is sending out a single character or a string which is the ascii-code or ascii-codeS of the digits
    of the value.
    But there are many other ways how your question could meant to be.
    So please describe in detail what you would like to do in the end.
    best regards
    Stefan
