Propeller Based Novelty Record Player?
WBA Consulting
I saw this a while back and thought it would be really cool to make one using a Basic Stamp. With my recent venture in to all things propeller, I thought it might be a better project for me learning the prop instead:
www.x-tremegeek.com/templates/SearchDetail.asp?productID=27638
My thoughts to work out are:
Audio circuit: With a stamp, this would just be a separate circuit that the stamp controls (volume, etc) With the prop, can the audio go through the prop? If I can go through the prop, I can add "song detect" that will stop when it detects "silence" for "x" amount of time.
Needle pickup: Gotta find out how to do this part, should be simple?
Drive mechanism: How to get the vehicle to maintain the correct turning radius? It appears that they have the needle floating with limit switches and as the vehicle drives "forward" it will turn left/right based upon keeping the needle between the limit switches?
Control: IR remote?
Display: Maybe just a few LEDs as a status display? (On/Off, 33/45rpm, low battery)
Anyone have any input on this for a Prop-newbie?
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
Control: IR remote?
Andrew Williams
WBA Consulting
THAT's a crazy thing ! LOL - ROFL
if i remember correctly the needle is pushing against a crystal which generates a small AM signal.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
