Need Help with LCD
Hai, im new with BS2 and i bought 2x16 LCD but not from parallax.
My question is, how to program it so i can write the top side with some text, and the bottom one to show my speed from encoder?
Thank You for your reply
If it IS equivalent then there is a wealth of information and sample code available on the parallax website as a download from the product page for the LCD display.
If it is a parallel display, you may want to consider buying the parallax serial display - they're inexpensive, and use only 1 pin on your Stamp, rather than 8. I thought I was getting a deal when I bought a handful of 2x16 displays for $5.00, but they were all parallel and took more out of my stamp than it was worth. With the serial displays, all you need is a single serout command to send data and commands to it.
And as you'll see there are command constants defined in the code for the parallax or equivalent displays that tell the display to do exactly what you are looking for. It is very simple to position data where you want it on the displays.
Let us know when you have the data on the display.
Dave
Ronnie
It is difficult to say where you may be going wrong without posting some code or diagram, but from what I'm seeing in the spec sheet, this should not be much different than other parallel LCDs. Line two starts at position 64 (40hex), so an LCDOUT command like the following should work provided your Enable connection from your LCD is connected to pin 0 of the Stamp:
LCDOUT 0,64, [noparse][[/noparse]"testing line #2"]
Look up LCDCMD in the BASIC Stamp Help screen to learn more about hooking up the LCD to the Stamp. Match those to the specs for this unit on page 3: http://www.pic16.com/wzsl/lma162a.pdf
It looks like the same pinouts as the Parallax example.
Rick
Post Edited (rixter) : 7/2/2009 3:59:16 AM GMT
