Programming Help requested. TV - VGA — Parallax Forums
cliff52cliff52 Posts: 2
edited 2009-07-02 01:18 in Propeller 1
If this has been done, I'd appreciate a pointer. I'd like an example or tutorial showing how to take a simple program written using TV out and modify it to use VGA out.
  • RaymanRayman Posts: 16,266
    edited 2009-07-01 18:07
    Easy way is to use TV_Text and VGA_Text... I have a "hello world" example, but I can't find it on the web right now..
  • cliff52cliff52 Posts: 2
    edited 2009-07-01 22:24
    Thanks for your link - your 2-Bit text and vga example is just what I wanted - the same task done both ways. I should be able to figure it out from there. I'll post again when I get a chance to try it out.
    Great. If you like that one, be sure to check out my BlackJack game!
    Ray
