Mosfet Part FQP6N40CF I have Data Sheet Need To Know Why this Part keeps going
I have a 175·watt mercury vapor yard light· that has a (65 watt florescent bulb that also has the ballast built in to it )
This bulb is made to replace the 175·watt mercury vapor·lamp
I changed the mosfet pair about a month ago
This is the second time·I had to replace the mosfets
The mosfets ·have shorted ·meaning that all pins have one ohm or less
The only thing that I changed was that it had· a 1.5 amp fuse and now it has a 1.5 amp·circuit breaker in it now
There are two mosfet on this board
FQP6N40CF Here is the Data Sheets for this Part
http://www.fairchildsemi.com/ds/FQ%2FFQPF6N40C.pdf
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 7/1/2009 2:48:19 AM GMT
··Thanks for any·
Sam
·Can you show the circuit?· N/A
I would have put more info but my Internet Concetion· has been going up and down all night
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 7/1/2009 2:45:14 AM GMT
It could be some high voltage spikes coming back from the built-in ballast of the new flors lamps or high heater current to fire up the new lamps?
A little more info would help!
_______$WMc%________
The Truth is out there············································ BoogerWoods, FL. USA
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 7/1/2009 4:16:23 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
This all the Info that I have on this board at this time
If you need a Photo of the board I can do this if need be
uba2021P
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 7/1/2009 8:48:48 PM GMT
1. Overheating. This can be caused by either more current than the FET can handle, or the FET not being 100% on, so the RDS_on is higher than it should be.
2. Higher voltage spikes on the Drain-Source connections than the MOSFET(and sometimes Zener in parallel) can handle. Chances are, you have a high freq. switching circuit in there somewhere since it's a CFL.
3. Gate voltage being exceeded. If your Gate to Source voltage exceeeds the maximum allowed in the datasheet, you can fry the gate, leaving the MOSFET half-way on all the time.
This may be a place to start. First, check the FETs to see if they are hot when the device is running. If they never get hot, chances are, #1 isn't the problem.
I've had·nearly the same bulb literally blow up from a big discharge... and in another, the FETs were fried (Phil's points 1,2, and 3 on steriods).
Philldapill
I had the same though about a· over heating problem
because the board where·one of the mosfet the board is discolored where it look like it has got hot
3. Gate voltage being exceeded. If your Gate to Source voltage exceeds the maximum allowed in the data sheet, you can fry the gate, leaving the MOSFET half-way on all the time
What would be a good Gate to Source voltage
I have two boards that I have had problem with
·CounterRotatingProps
One board· was where the mosfet are·shorted and one of the cap had blow-en apart there had been Thunder Strom that night
big discharge may have done in that board
This board I have not try-ed· to fix because the cap has just numbers and letters I have found same part # for this part yet
··Thanks for any·
Sam
