PSION note book windows CE running the prop IDE
Hi guys does anyone know if there is a copy of the parallax IDE software for the prop chip that will run on Windows CE???? I also want to run the basic stamp IDE on Windows CE if anyone know that as well thanks
of course there are older versions
but just try to start it on windows CE
Why would you even bother? The psion devices are not i386 processors and the Windows CE ABI is not compatible with the standard Win32 ABI.
The short answer to the question is, No there is no current way of programming a propeller from Windows CE. I toyed with the idea a bit but gave up pretty quickly.
When I want compact and portable I use an Acer Aspire One.
Missed it by ->" "<- that much!
