Little Step-U vs BiStep motor controller.
I've purchased these two controllers. I used the Little Step-U to control an Oriental Motor PK244M-02B motor. I've connected it as described in the documentation and the motor seems to work. I could never get it to step at a faster rate than 250 steps per second. Even at this rate, the motor would shudder sometimes and the torque was too low for my application. Scratching my head and thinking towards another solution I thought I'd try the BiStep motor controller as it would handle a bipolar motor. Well it arrived. Before ordering another motor, I thought I'd try the OE motor again. I thought I'd wire it bipolar at first as I thought it may give the better RPM. Instead I wired it as a unipolar and use the sample code just to check things out. It worked as expected for the test. HOWEVER, while modifying the code to see if I had the same limitations as before, I found that it was stepping along happily at 800 steps per second with more top end and all the torque I could use. Anyone have any idea why this would be? I'm using a BS2px24 and the PDB. I'm happy with the results with the BiStep but thought someone may have an insight on the differences.
Fred
Why be one if you can't act like one? Knoxville, TN
Fred
Controller name Power requirements
Bi-step 6.5 - 15 V, 1 A
Little Step U 35 V, 3 A
