Propstick power
I put a small jumper wire from the USB +5VDC connection to pin 12 on the propstick and it works fine to power the propstick from the USB port. GREAT for traveling on the plane or while waiting to be seated in the restaurant !
Earl
Earl
-heliboy
I though I would answer, Earl hasn't been around for a while.
Jim
1. The USB port can only supply about 500ma of current. That is total to the Propstick and all the items you stick on the outputs.
2. It is best to use a USB Hub between your computer and the Propstick, as it is better to replace a Hub than a Mother Board.
I just bought a USB 2.0 Hub for $9.00.
Jim
