LED Power Supply
I'm currently in the process of designing a Propeller based lighting instrument, based upon a trio of RGB LEDs (1W per channel per LED, for 9W power total). The design is overall powered from an unregulated 18V DC supply, and my intention is currently to power the Propeller and other sensitive electronics from a linear regulator, and use the Propeller to provide the LED power supply. The design means the power load can vary wildly and rapidly; therefore the power supply will have to be relatively resilient and will also have to be fast acting.
The LEDs are 3.3V and common anode; my question is how best to supply them with the power they require and regulate it. I'd prefer a software solution; particularly one which can give me statistics back to report to the user (Along with housing temperature information).
Again, this is assuming there are 6 connections on each LED module, so that each color doesn't share any common connections with the others. However, if the LEDs share a common cathode, well, you'll have problems.
With this setup, you should be able to drive the whole set with 3 I/O pins, using PWM to vary the intensity of each color. Each color would be driven from a seperate IO pin.
Using the TI chips is also possible even with the larger current draw of the 1W LEDs. There are apps notes on TI's site for taking the output of their IC and using a MOSFET for controlling higher currents. However you could just connect the Prop to the mosfet and do something similar if the Propeller has free cogs/code space and I/O in your application.
At the moment I am prototyping a product that has 8 groups of red, green, blue LED controlling circuits. The brains of the device is the Propeller. There is 24 outputs, one to each LED. The Propeller will do all the PWM or BAM for controlling the intensity of the LEDs. The Propeller is switching a n-channel MOSFET so that each channel can control up to 7.5A. The product, which I call Illuminator-CA (where the CA stands for common anode) has a switching regulator to the electronics portion. The voltage that is feed into the device is routed directly to the LED voltage. The device will accept DMX512-A for control or have built in patterns. Eventually there will be an interface where users can design their own patterns and store them on the device. I attached an image of the prototype, but the final product will change slightly. I am going to be selling the prototypes, though at a cheaper price than the final product. Let me know if this device is of any use and we can work out a deal.
So - did you get your question answered OwenS? If not, let us know what you are looking for still and we will try our best to up.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
It looks like you are going directly to the FET's gate (with an R inbetween). Could you please tell me the type of MOSFET that does 7.5A with an Ugs of 3.3V?
TIA,
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
In my circuit the Propeller output is taken straight to the gate. Theres is a pull down resistor on this I/O to ensure the MOSFET is off and not floating. There is no resistor between the Propeller output and the MOSFET. I know the circuit seems so simple, I keep thinking I might be missing something. What do you think?
Sorry OwenS, I don't mean to take your thread off topic. Jump in if you have more questions and need help.
www.tdswieter.com
Typically, you have an 10R .. 20R going to the gate. This reduces switching speed a bit (RFI; scope for overshots) and limits the current from the prop while switching on/off. You are charging/discharging the gate. 1nF typically according to the data sheet.
Better use a gate driver.
Also, I don't know how you drive LEDs with constant voltage and without an resistor. But maybe your LEDs have something built in.
Nick
YADRO
The other big problem is that Incandescent light bulbs are beating us in the efficiency game here!
Post Edited (OwenS) : 7/1/2009 3:35:40 PM GMT
Can anyone suggest a method of voltage protection? I was thinking a zener diode between the 18V and 0V rails, in order to trip the fuse?
Nick
YADRO
Thanks for pointing out figure 2 in the data sheet. I reviewed that for a few minutes and I believe I understand it better. If I am driving the gate with 3.3V, then the on-resistance will be between 1.5 and 2.2 and probably closer to 1.5. I take this to mean that the MOSFET will dissipate more heat with higher current loads because the resistance isn't as low. I could therefore say the specification of the Illuminator is less than the actually MOSFET current driving capabilities to account for the higher on resistance.
Maybe in another thread or PM you can tell me more about gate drivers. I don't fully understand why it would be needed - again, I am just now researching and designing with MOSFETs so it could be something obvious I am not understanding.
www.tdswieter.com
Typically.
The problem with MOSFETs is, that they all need at least about 4V on the gate to fully open. That's why I asked. Now if you drive them with 3.3V, you can't charge the gate fast enough. So there's a certain time while switching when the resistance is high. Power loss, heat.
The other thing is, that you should not switch on/off too fast. Or you will get RFI with a lot of harmonics and the FCC (or how they are called) ringing at your door bell.
With drivers (comparators would work too), its easier to get a high gate voltage, and supply the necessary currents.
Oh, and sorry, it is Figure 4, not 2. -> A Vgs of 8V would be desirerable.
Nick
Nick
YADRO
