Demo Board Library? — Parallax Forums
Demo Board Library?
W9GFOW9GFO Posts: 4,010
edited 2009-07-01 23:00 in Propeller 1
Now that I have a working Demo Board (built using two bad boards off the freebie table), I want to run some code on it. It seems that there are a lot more programs that are meant to run on the Demo Board that don't come with the Prop Tool. Where are they?
Rich H
    edited 2009-06-30 18:02
    They would be in the Object Exchange. Make sure you have a newer version of the Prop Tool. Quite a few objects and demo programs have been added. Some of them are meant for the Demo Board, particularly those with audio outputs.
  • W9GFOW9GFO Posts: 4,010
    edited 2009-06-30 19:43
    I was hoping for a list of ready-to-go programs for the Demo Board, aside from those that come with the Prop Tool. I've since found Turbulence, Life and JetPack. I'm looking for more of those, especially ones that that use the TV driver.
    Rich H
    edited 2009-06-30 19:54
    How about this?
    http://forums.parallax.com/showthread.php?p=770318
    OBC
    New to the Propeller?
    edited 2009-06-30 20:36
    Yup, now that's what I'm talking about!
    You need to get Chris to add that to the "Getting Started and Key Thread Index".
    Rich H
    Excellent thread, I was going to ask the same question as I am also resurrecting a demo board from the freebie table. I also got a Propstick USB from the freebie table that is in need of some serious attention, but I think I can get it working with a new prop chip. The USB to Serial portion works fine, so worst case, I have another USB-Serial adapter.
    Andrew Williams
    WBA Consulting
    IT / Web / PCB / Audio
