Parallax Servo Controller Serial pc connection — Parallax Forums
cereal2ndcereal2nd Posts: 11
edited 2009-07-03 15:34 in Robotics
hi,
is it possible to directly link (with or without a max 232) the Parallax Servo Controller (Serial) to a pc?
and how should i wire this connection?
thanks?
  • PrettybirdPrettybird Posts: 269
    edited 2009-06-30 12:48
    The older Parallax servo controller used USB
    edited 2009-07-01 20:25
    There is an RS-232 interface schematic for the PSC on the following froum page. Take care.
    http://forums.parallax.com/showthread.php?p=640507
    Parallax Engineering
  • cereal2ndcereal2nd Posts: 11
    edited 2009-07-02 08:50
    and how would i connect this directly to a another (non parallax) microcontroller?
    edited 2009-07-02 19:47
    I'm not sure I follow you. Your original question was how to connect the PSC Serial to a PC serial port. What are you trying to connect to what in the second question?
    edited 2009-07-03 06:16
    well i was thinking of connecting it directly to a simple serial port of a microcontroller
    so a ttl serial port and not a real serial line, how can i do this?
    edited 2009-07-03 13:53
    Theoretically, you could directly connect the PSC to any TTL serial port on a microcontroller. Practically, it's safer to include a 220 Ohm resistor in series with each signal line. This will limit the "fault" current in case there's a programming error that accidentally makes a receive line into a transmit line.
    nvm i bought the pololu one
