anyone have any suggestions on this idea?
I'm just wanting to give some robot
building a try. I looked at the stamp
a couple years ago but never got started.
I'd like to build a platform on which to
expand that will wander around the
yard, avoiding obstacles. (bumpers or
ir?) Differential drive, 12V gear motors
~60rpm 10A stall. 30lbs payload resonable?
I have some of the mechanical skills required
but im still lost in the electronics.
Also, is it possible to keep the robot
contained by having it detect the color
of the surface it is on? Any shove in the
right direction would be greatly apreciated.
thanks,
Matt
thanks,
Matt
The more you learn the more you find you don't know. It is neverending. Confucous 550 BC
welcome to the forums! All the things you mention are possible. You might want to start with one of the 'simple' robot kits, like the BoeBot. The size and sophistication of the 'bot you'd like to build is probably not the first step to take if both programming and electronics are new for you. If you get, say, a BoeBot, you can mess around with both aspects and ramp up to bigger and better things as you learn. Another route is to get a "demo board" of some kind and build things temporarily and experimentally on your work bench. This stuff requires building up and tearing down a lot - the more work space you have, the better. You'll need some basic electronics tools and equipment. As Prettybird mentions, the forum is a great place for assistance - we'll help you figure out what you need.
@Prettybird: that's a monster alright ! --- does it deliver hot coffee too? [noparse]:)[/noparse])
- Howard
1. try a kit such as the boebot, there are a number of other kits that can be modied easily
2. build a smaller version of the large bot
If you haven't built a bot at all, I would do 1 first, then 2 and then build the bigger bot.
The other thing you might want to think about is building a remote controlled small bot to start with. I normally do this when trying a new base. I build a base, put a micro (I normally use hte prop), with a RC receiver, mtoor controller, etc. This give a chance to learn the electronics around the basic bot without mixing sensors etc. as well.
I recommend starting with a BOE bot. You can learn a lot and get a lot of support and examples.
My Robots
learn the basics on a smaller sacle
matt
