Roaming with ping and ServoPal
·I have a boe bot that i have successfully programed to roam with the ping sensor on the servo . I am having trouble now programming it work with the ServoPal .
·I can get the servo pal to work with IR sensors , but not with ping sensor·. The program I wrote is likely the problem ,the program loads into BS2 fine ,But only ping sevo moves with dectection , servos connected to the ServoPal do nothing. does anyone have a working code that I could get a copy of ?I have the servoPal connected to pin 12 and 13 , pin 12 is the servo controller it Controlls two servos on one pin , and pin 13 is the Alarm , im using the servopal to gen. the pulse signal to make everything smooth as in it does not have to stop to look around it can do it on the move .maybe its not posible ,But it looked good on paper.
Post Edited (Realrocker) : 6/29/2009 11:44:58 PM GMT
Parallax Engineering
