DDS on Propeller? — Parallax Forums
DDS on Propeller?
DroneDrone Posts: 433
edited 2009-07-02 05:52 in Propeller 1
Hi All... Has anyone implemented Direct Digital Synthesis (DDS) on the Propeller? Did a brief search of the forum and ObEx and didn't come up with anything. Will dig deeper tomorrow.
Thanks, David
  • TubularTubular Posts: 4,770
    edited 2009-06-29 20:46
    Hi David,
    This comes up from time to time. What frequency sine waves were you thinking? 0-100Hz for 3 phase motor control, or higher? I believe the Prop2 might be able to do DDS nicely (there was something in the webinar earlier this year).
    I looked at it briefly before deciding the AD9959 evaluation board (4ch DDS for $250) was good value for a nice bit of ready made test gear
    Here are a couple of related threads from earlier.
    http://forums.parallax.com/showthread.php?p=739083
    http://forums.parallax.com/showthread.php?p=815643
    and towards the end of this one
    http://forums.parallax.com/showthread.php?p=596612
    cheers
    tubular
  • DroneDrone Posts: 433
    edited 2009-06-30 12:51
    Hi Tubular,
    I'm looking for a couple hundred kHz with an 8bit D/A and maybe 24 bit DDS control and accumulator. Looking at the assembler instructions though was a bit of a let down. I had forgotten PASM instructions take at least four clock cycles. So if the simplest DDS loop takes around 10 instructions, even with the system clock at 80MHz I don't think I'll even hit 100kHz. Maybe I'll look at an Atmel AVR part. AVR instructions are typically one clock cycle each, which will result in better performance even with a system clock of 20MHz.
    I'll have a look at the links you provided as well.
    Thanks for taking the time to reply, David
  • LeonLeon Posts: 7,620
    edited 2009-06-30 12:55
    I've used a software DDS on an AVR to get up to 200 kHz or so with a 2313:
    www.geocities.com/leon_heller/minidds.html
    A 20 MHz Tiny2313 would be a lot better.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-06-30 16:14
    Hi Tubular, your links were posted with extraneous br tags that seem to render them unclickable for me (use the forum URL button instead to encapsulate links). Below edited links seem to work... Plus I've added some more links on this subject. Best Regards, David
    * Heterodyne Sine wave generator - What if Tesla had a Propeller to play with?
    * OBEX update: PWM_32_v1
    * Control Phase on NCO
    Here are a couple more links I found that might be helpful:
    * Problems getting Sinewave Generator to output full bandwidth
    http://forums.parallax.com/showthread.php?p=744980
    * SPIN CODE EXAMPLES FOR THE BEGINNER (Public Version)
    This is Tracy Allen's post with sinewave0.spin, sinwave1.spin, sinwave3.spin
    http://forums.parallax.com/showthread.php?p=606978
    edited 2009-06-30 17:47
    Hi Leon,
    Yes... Your AVR DDS page and the link to Jesper's DDS is exactly what I've been thinking about. In looking at my ASM minimal DDS pseudocode for doing this and it became apparent the typical 4 clock cycles per instruction required in PASM is problematic. The PASM code at 80MHz system clock will run significantly slower compared with the AVR at 20MHz.
    Jesper's AVR code is almost identical to what I came up with in terms of the DDS main loop. I looked at protoboarding a DIP28 ATMega168-20PU at 5V to implement the DDS (instead of the 2313; I only have a 168 on-hand) with a 16MHz crystal (no 20MHz on-hand) with a discrete resistor (30k/15k so 6-pin ISP can work in parallel) 8-bit R2R DAC. Argh, it turns out with the 168 vs. the 2313 if you want to use a crystal and USART TXD/RXD, you can't get a GPIO port bank with full 8-bits. This adds instructions to the main DDS loop and slows it down (but not by much compared to PASM. Each AVR ASM instruction adds 1 clock cycle, PASM adds at least 4.) IMHO This is a deal-killer in DDS applications like this with PASM.
    I'm by no means giving up on the Propeller. If time permits, I'll port my solution to PASM with a Spin wrapper and freely distribute the code on ObEx.
    Yes I know a middle-ground solution is to implement the DDS in the likes of a CPLD in VHDL etc. But for 200kHz 8-bit waveforms, I'd rather find a very low cost single chip DIP micro-controller solution so everyone can use it on the bench.
    Best 73's Leon, David
  • AribaAriba Posts: 2,695
    edited 2009-06-30 18:56
    Drone said...
    Hi Leon,
    Why that? PASM: 80MHz/4 = 20MIPS, AVR: 20MHz/1 = 20MIPS, but only 8 bit MIPS.
    For a DDS, you need additions with more then 8 bits, so the propeller should be faster for this.
    Here a possible minimal DDS for 100 kHz with a triangle wave, instead of a sine (not tested):
    entry    mov dira,#$FF     'DAC on PA7..0
    ddsloop  add phase,freq    'dds
             abs t1,phase      'sawtooth to triangle
             shr t1,#23        'shift to bit 7..0
             mov outa,t1       'output on PA7..0 to the 8 bit DAC
             jmp #ddsloop      ' 5*4=20 clocks = 4 MHz sample rate @80MHz
    freq     long 4_000_000 / 100_000  'frequency
    phase    res  1
    t1       res  1
    Andy
    Hi Andy,
    The code below is scraped from Jesper's source at www.myplace.nu/avr/minidds/index.htm is for a DDS with 8-bit DAC, 24-bit accumulator, and 24-bit adder. It takes 9 cycles at 20MHz for a 2.2MHz fastest loop. Assuming 4-cycles per instruction (best case) the PASM code you presented would take 20 clock cycles at 80MHz tor a 4MHz fastest loop. So you are right, if my assumption of 4 cycles per instruction in PASM is correct, the propeller is roughly twice as fast as the 20MHz AVR with your PASM code. I stand corrected. Note, Jesper's code uses a data table for sine, triangle etc.
    I'm not good with PASM yet. How would you implement your code with a data table? Say 256 steps or 16x16.
    Thanks - David
    ; main loop
    ;    r28,r29,r30 is the phase accumulator
    ;      r24,r25,r26 is the adder value determining frequency
    ;     add value to accumulator
    ;    load byte from current table in ROM
    ;    output byte to port
    ;    repeat
    LOOP1:
            add        r28,r24            ; 1
            adc        r29,r25            ; 1
            adc        r30,r26            ; 1
            lpm                        ; 3
            out        PORTB,r0        ; 1
            rjmp    LOOP1            ; 2 => 9 cycles
    Post Edited (Drone) : 7/2/2009 12:01:44 PM GMT
