Pink IP address Read
Can I set the pink to use DHCP, Set my Modem/router/DSL to DMZ, then read my non static IP address given by DSL? Then using the Stamp BS2, compaire this address to the last·saved. If this address has changed Email the new address to my cell phone and then save this new address to memory, for later compaire.
Not sure I follow you…the PINK can read its own IP address and you could report a change to that. But if your DSL IP changes, the PINK has no way of knowing that because it does get that address. Now, on the other hand, you could UDP a message to a remote system and the source IP will be available that way.
Parallax Engineering
Just checking before I buy!
Post Edited (Larry~) : 6/29/2009 10:16:21 PM GMT
- Stephen
This is a domain name server service,·but if my ISP changes my address ( 75.15.123.198 to 75.15.121.189)·I need to update this service to reflect this change. So if the pink is running through the dsl modem/router and is setup to pass through (DMZ mode)·which (i think) will allow it to have the DSL address assigned to it. And if the pink can check its own address and be read by the stamp then I can email (text) myself anytime there is a change in my dsl address.
- Stephen
I just want to know where the pink is at all times so I can use its webpages from anywhere.
On my system when I use DMZ the PINK still has a local intranet address.
I had posted on here seom details of my own home-brew alarm system which is quite impressive. I would say if you wait a month or so I will be publishing my home alarm system project which also includes a PINK interface, but two things have hampered me publishing the details of the system...It was working flawlessly and sending me text messages whenever a zone was breached or optionally when even normal (authorized) activity took place. My ISP recently changed to different ports for the outgoing mail and requires SSL causing my text messages to stop working. When I first developed the system I was in a cubicle which had an outside line with a STATIC IP coming right to my desk. So what I did for the short term was have the system send UDP messages to a box on my desk. These messages also gave me the updated status as well as the current IP address @ my house and I could then login to the web interface using that address. However my new office has no such outside access line and is on a different part of our network. Until I find a new work-around I probably won't do anything else with it. But I do hope to come up with something soon.
now one more thing if you email a computer from the pink check the header information for sent from address, this should show your dsl address to get to the pinks web page incase it changes. Does the pink only use specific ports ? or can they be changed what are these ports ?
for this site you will need incoming pop3 of 110 and outgoing smtp of 587
now you guys sell the netburner kit and could make some program changes to your existing software which would allow SSL
http://www.startlogic.com/startlogic/hosting.bml
Well if all else fails read the manual
So the pink only uses port 25 with or without Authentication
Doing some research I find that port 465 is used with SSL and authentication
And port 587 is used with and without authentication it seems most ISPs are getting away from port 25 because of the spam factor
Now how hard would it be to change the program that Parallax wrote in the PINK to use 587 instead of 25 would they be willing to let us have access to this program or sell two versions of this nice product.
I would like to know if there are lots of people who's ISP is still using port 25 in outlook its under Tools, Account Settings, then click on one of your email accounts then More Settings, Advanced its the SMTP setting.
Dave
