Using Silkscreen printing with Eagle
![william chan](https://forums.parallax.com/uploads/userpics/RBTCEMRWP85K/nQFR9OII9OM33.jpg)
Hey,
How I do make Eagle print only the bottom copper layer so that I can make a silkscreen from the the bottom layer pattern?
Thanks a million.
www.fd.com.my
www.mercedes.com.my
Post Edited (william chan) : 6/29/2009 2:27:32 PM GMT
Thanks a million.
www.fd.com.my
www.mercedes.com.my
You are a genius !
Which layer are the top solder mask and bottom solder mask?
Do I need to mirror before printing them?
www.fd.com.my
www.mercedes.com.my
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
I think layer 29 is correct.
But when I try to print layer 29 alone, it the printer prints only grey instead of black.
I need the printout to be black to make a silkscreen for the solder mask.
How do I make the printout black?
www.fd.com.my
www.mercedes.com.my
Method 2*) Export to gerber and use a gerber file interpreter to print .stc file
*Method 2 is better way because then you can use for all cad programs.
CMP: Top Copper
SOL: Bottom Copper
PLC: Top Silk Screen(Some call Legend)
PLS: Bottom Silk Screen
STC: Top Solder Mask
STS: Botom Solder Mask
DRD: Drill Data
PADS: Used for making stencil for surface mount soldering
