Way to read voltage using MoBoStamp-pe
Hi,all;
I am new with Mobostamp. I need to read analog voltage output from two sensors using daughter boards of A and B. I heard that Mobo has built-in A to D. Does anyone can how I can make simple code using what pins from each daughter boards? I believe there should be Q&A regarding this....or would you let me know the link where I can find the discussiong? If simple code for this, it will be best!. Output voltage of my sensors are 0~3.3V.
Caleb
Caleb
www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/CategoryID/12/List/0/SortField/0/Level/a/ProductID/451/Default.aspx
Pages 6 & 7 discuss how to use the built-in A to D converters.
By the way, in order to do data logging, I found "PLX-DAQ" in the website, and which seems very good my purpose. I download the software and example....but, I wonder if there is any detail explanation to do step by step...which I couldn't find so far.... would you direct me if there is any additional discription for step by step....also, would you adivse if this program is the proper one you can recommend for biginner or if there is something else which I can consider later?
Thanks agan, caleb.
