What is happening at the Expo?
I am so sorry to be missing the Expo at Parallax. I also slept in and missed the Webinar.....so, can some of the folks at the expo gives us a run down of what they are seeing and hearing? How about some pictures?
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
www.tdswieter.com
Attendance is really high! Lots of people here, vendors and presentations.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Safety Tip: Life is as good as YOU think it is!
Almost all of it was eight feet over my head. I'm sure (based on past Webinars) they will edit it down and post it for all to see.
Wish I were there!
Roger
Prop I - 64 I/O likely ???
External RAM
Overclocking
Thanks. I am really interested in Prop II but it is too far away.
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
· Search the Propeller forums (via Google)
64 I/O Prop I: Not likely. The cost to actually produce it is fairly high. Spending the money would impact things like the Prop II and Chip is not convinced that it would sell well enough (even over the product lifetime) to justify spending the money when the Prop II will provide the 64 I/O pins and a lot more. I'm sure if someone would make a compelling case (with hard sales commitment attached) he would be willing to finish it, but hobbyist volumes and just wanting it isn't enough with the Prop II under development.
External RAM: He talked a little about that with regards to the Prop II. He may add some extra features / instructions to help.
Overclocking: He discussed for a while. I didn't hear anything new. It all depends on operating temperature and supply voltage. The worst case instructions are probably ADD and SUB because of the long carry propagation time.
But if them improve chip to can be placed (with other improvements) on 32/64 and have same chip to both.
That cost in not so big. And have more Industrial use
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
It's been really quite enjoyable.
