Need a Person who has 2 demo boards to see if code works
Well, my other board broke, and all the other homade ones·I have are not equipped with a vga port. Just load the EEPROM onto both boards, and connect them together with some wires, and follow the instructions in help.
(The Connect button isn't there, you have to press v. To set the tx and rx pins, press p. to get to settings, press c)
Tell me how it goes!
(No SD interface or DOS Prompt yet, but i'm working on it!)
I could give more info, but I don't want to spoil it. It is the most glitch free piece of spin I have ever written!
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
Post Edited (ProcessingData...) : 6/27/2009 4:52:14 PM GMT
START:·
>Saving Data. . . .
>Signing OFF
I tried your code and I get Error: 0001 on both demo boards.
My setup:
Demo board 1: Host
·PS2 mouse
·PS2 Keyboard
·VGA Monitor
·TX Pin 00
·RX Pin 01
Demo board 2: Slave
·PS2 mouse
·PS2 Keyboard
·VGA Monitor
·TX Pin 01
·RX Pin 00
Tried it again with ground connected between two boards. Same error.
Question, can the code just exsist in RAM or do you have to download to EEPROM? Probably just RAM as you have to modify settings in·after it's been loaded·anyway, (TX, RX, Host, Slave)
Used "p" to set pin numbers
Used "c" to set Master/Slave
Used "v" to start program
Anything I'm missing?
Jim
(Either·RAM or EEPROM, it doesn't matter...)
START:·
>Saving Data. . . .
>Signing OFF
Report back soon.
Jim
START:·
>Saving Data. . . .
>Signing OFF
Jim
So, you did get the "connected" message?
Sorry about the lockout! I hope it doesn't happen again.
START:·
>Saving Data. . . .
>Signing OFF
