0831 help with code
I have a bs2sx connected to an adc0831 and using a voltage divider to transform voltage from a car battery down to 0-5v. Everything works great, as my lcd correctly displays 0-5 as it should. However, now that·I have converted to voltage, I can't figure out the code to convert the 0-5 volt reading back to 0-14 or 15 so the display will show actual voltage of the battery. Here's the code:
CLR CON 1 'lcd1620
I CON 254 'lcd1620
N9600 CON $40F0 'lcd1620
[noparse][[/noparse] Declarations ]
adcBits VAR Byte
v VAR Byte
r VAR Byte
v2 VAR Byte
v3 VAR Byte
[noparse][[/noparse] Initialization ]
CS PIN 0
CLK PIN 1
DataOutput PIN 2
DEBUG CLS 'Start display.
[noparse][[/noparse] Main Routine ]
DO
GOSUB ADC_Data
GOSUB Calc_Volts
'GOSUB Display
GOSUB lcd
LOOP
[noparse][[/noparse] Subroutines ]
ADC_Data:
LOW CLK
LOW CS
PULSOUT CLK, 210
SHIFTIN DataOutput,CLK,MSBPOST,[noparse][[/noparse]adcBits\8]
HIGH CS
RETURN
Calc_Volts:
v = 5 * adcBits / 255
r = 5 * adcBits // 255
v2 = 100 * r / 255
v3 = 100 * r // 255 '· new line
v3 = 10 * v3 / 255 '· new line
IF (v3 >= 5) THEN v2 = v2 + 1 '· new line
IF (v2 >= 100) THEN '· new line
v = v + 1 '· new line
v2 = 0
ENDIF
RETURN
Display:
'DEBUG HOME
'DEBUG "8-bit binary value: ", BIN8 adcBits
'DEBUG CR, CR, "Decimal value: ", DEC3 adcBits
'DEBUG CR, CR, "DVM Reading: " '· new line
'DEBUG DEC1 v, ".", DEC2 v2, " Volts" '· new line
RETURN
lcd:
SEROUT 6,n9600,[noparse][[/noparse]I,CLR] ' Clear the LCD screen.
PAUSE 1
SEROUT 6,n9600,[noparse][[/noparse]"Battery:"] ' Print the label.
SEROUT 6,n9600,[noparse][[/noparse]DEC1 v, ".", DEC2 v2, "··· "]
RETURN
I'm sure there's an easy answer, and I swore to figure this out myself, but I'm to the point of accepting a little help.
Thanks...Ron
CLR CON 1 'lcd1620
I CON 254 'lcd1620
adcBits VAR Byte
v VAR Byte
r VAR Byte
v2 VAR Byte
v3 VAR Byte
CS PIN 0
CLK PIN 1
DataOutput PIN 2
DO
GOSUB ADC_Data
GOSUB Calc_Volts
'GOSUB Display
GOSUB lcd
LOOP
ADC_Data:
LOW CLK
LOW CS
PULSOUT CLK, 210
HIGH CS
RETURN
Calc_Volts:
v2 = 100 * r / 255
v2 = 0
ENDIF
RETURN
Display:
'DEBUG HOME
RETURN
lcd:
PAUSE 1
RETURN
Thanks...Ron
- Stephen
adcresult = (adcresult*10) / 33
See if that works for ya.
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
It appears code is easier in theory than in reality. Your math makes total sense, but I've tried it, and can't get it to work. Problem is the code breaks down the variable because of the remainder then puts it back together "v" and "v2. I've put the math to every variable possible with no luck. Gee....if only the stamp would calculate decimals!
·Go here >>>> ADC0831
Here is what part of· what Chapter 3 says
·Calculate Voltage
Now that we know the decimal equivalent of the ADC0831’s binary output, we can do a
few calculations to get the measured voltage. To find out what voltage the decimal
number corresponds to, we need to calculate where in the voltage range the number falls.
Here is an effective way to think about the problem.
( Where they have·5 Volts you are going to ·use 15 volts for the scale·)
• We know that the voltage is on a 0 to 5 volt scale, and we know that the
· ADC0831’s output is on a scale from 0 to 255.
• In other words, the measured voltage is to 5 as the A/D output is to 255.
This translates to fractions as:
Voltage = Decimal A/ D Output
____________________________
······ 5·············· 255
We can re-arrange this equality to calculate the voltage:
····················· 5× (Decimal A/D Output)
Voltage=···_________________________________
·································· 255
So, now we know to multiply by 5 and divide by 255 for a 5 volt scale with 256 levels.
We can calculate the voltage from Figure 3-6 where the ADC0831’s output is 10100101
= 165. The measured voltage is:
= 3.24 Volts rounded to two decimal places.
·················· 5 ×165
·················· _______
·Voltage· =·················
To calculate and display this voltage using the BASIC Stamp, we’ll add some code to
both the Calc_Volts and Display subroutines. First, the voltage equation needs to be
expressed in PBASIC code. Here is an example of some code that could reasonably be
expected to work.
v = 5 * adcBits / 255· ( So you are going to use· v = 15 adcBits / 255 )
This PBASIC calculation looks like it will give us the output we want, but it won’t. It’s
instructive to try it this way and see what happens. Modify the Calc_Volts and Display
subroutines in Program Listing 3.1 as follows:
Calc_Volts:
v = 5 * adcBits / 255 '· ( So you are going to use· v = 15 adcBits / 255 )
Resolution
The BASIC Stamp is now programmed to accurately calculate the voltage associated
with the ADC0831's binary output, and the calculation is accurate to the hundredth’s
decimal place. Although sources of calculation error have been eliminated, there is
another source of error that caused by the resolution limitation of the A/D converter.
The A/D converter chip we are using is capable of 256 binary values. This means that
amount of the voltage range covered between each of these discrete values. Since the first
value is zero, there are 255 voltage steps. The step size is given by:
·( Where they have·5 Volts you are going to ·use 15 volts for the scale·)
······································ 5 Volts
················ Step Size =· _________· = 0.0196 Volts/step 0.02 Volts/step
····································· 255 steps
With this in mind, each time you adjust the pot, the converter comes close to
approximating the analog value, but it's not exact because of the resolution constraints.
So, there is still some uncertainty at the hundredth’s decimal place. In some applications,
the uncertainty is stated along with the measurement. Assuming the ADC0831 rounds at
the half way point, we can use this convention to read the voltage from Figure 3-9 as
"3.24 volts plus or minus 0.01 volts."
··I hope this helps
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 6/28/2009 9:06:33 PM GMT
thank you so much, it works great. I shall name my first child after you!
You Rock!
I one thing I would like you to do for me is when you get your code to work right is to Post it· and share it
··Thanks for any·
Sam
