strcomp doesn't seem to evaluate right - Please help
Shane M
I am basically reading from a serial port. (Currently just typing a word).
My routine should receive the string (it does), see if the string received (strin)·is DIFFERENT from the last time (using strlast) and if NOT the same I am having my EMIC text to speech chip say the word AND copy the strin to strlast.· If it IS the same it should simply ignore the block.
I was on support for a while and even the support guy was stumped.
Here is the code snippet:
Basically it always evaluates as if the strings don't match.
Can anyone help me?
Shane Merem
www.websiteforge.com
www.magnusoft.com
repeat 'serial.RxStrTime(5000,@strin) serial.RxStr(@strin) 'if the string received is different then say the word if (not strcomp(@strin,@strlast)) emic.say(@strin, true) 'have emic say text serial.str(@strin) ' this is just a debug serial dump for myself emic.WaitNotBusy ' wait until emic is not busy CopyString(@strlast,@strin) ' copy the strin to strlast (this DOES work) emic.say(@strlast, true) 'have emic say text serial.dec(strsize(@strin)) ' I dumped this to make sure the strings were viewed as the same size serial.dec(strsize(@strlast)) emic.WaitNotBusy 'this is my copy routine. It does work. PUB CopyString(dest,src) byteMove(dest,src,15) dest[noparse][[/noparse]strsize(src)+1]:=0
Can anyone help me?
Shane Merem
www.magnusoft.com
Byte strin[noparse][[/noparse]15]
Byte strlast[noparse][[/noparse]15]
Thanks for your help
strin[noparse][[/noparse] 0 ] := 0
strlast[noparse][[/noparse] 0 ] := 0
CopyString also has to be
bytemove(dest,src,strsize(src)+1)
You don't need to add another zero terminator since the bytemove copies the one from the source string.
The copystring change is what ultimately fixed it. Thank you!
