Wireless project..... am I being to hopeful?
Hello
I am planning to build a multi-channel TX/RX system using a spare Basic stamp+LCD screen I have in the workshop.
I was hoping to use this RS232, 16 channel servo controller :
http://www.active-robots.com/products/motorcon/pololu-16-servo-controller-kit.shtml
The communication between the stamp and the above module was going to be using a pair of these RS232 modules:
http://www.active-robots.com/products/radio-solutions/a-rm001p-details.shtml
Obviously I have some interfacing to do, but does anyone foresee any problems?·· I am thinking it looks a bit too easy to make a 16 channel radio system.
Any input would be great
Many thanks
Steve
Many thanks
Steve
If you're trying for distance, always underestimate what the radio manufacturer tells you as to range.
For good wireless rules-of-thumb, go on the B & B Electronics site and download the white paper on data communication:· "10 Commandments of Wireless Communication".· www.bb-elec.com
Cheers,
Tom Sisk
http://www.siskconsult.com
Post Edited (stamptrol) : 6/26/2009 3:19:42 PM GMT
Just wondered if these links were stable. I intend to control a complicated radio controlled boat with the system. I know the range is pretty limited, but what are the chances of interference?
With any radio link, you can't assume anything about the reliability of the link. These are unlicensed low power units and are subject to interference from other sources.
You need more information from the vendor. In particular, how is the error checking done? Is there error correction (retries)? How does the module signal that errors have occurred?
You have to design your control system to be fail-safe in the case of link errors.
The main problem I can forsee is the fact that I will need to read around a dozen pot positions and convert those to servo positions.
RCTIME is just going to be too slow if I want a reasonable response rate from the servos.
I was thinking of driving simple 555 pulse generators and reading them using Pulsin. Would that be quicker?
I quickly looked over the PDF file for the IC and just found some Basic code via Google..... I shall have a play
Steve
Post Edited (Steve2381) : 6/28/2009 9:10:45 AM GMT
