can see pink on LAN but not on WAN
Hello All,
I can control my stamp via the pink module through my LAN, but not through WAN.
The PINK is connected through a router.
I thought I could see the module if I set the router with port forward setting.
My problem is I've tried port forwarding.
I've changed the DHCP to static IP.
Is there something else I need to do?
Shmow
Shmow
- Stephen
Thanks for the replay. I would like to avoid DMZ setting.
I figured my port settings might be off (set at 80 to 110 on the router). Could that be it?
It may sound lazy on my part, but I want to have the PINK connected through the router to make my life easier.
Cheers,
Shmow
Also, your ISP may be blocking incoming requests, one way to test this is to use a service like shields up from GRC to see if the port is actually open and accepting connections, you can find it at this link·https://www.grc.com/x/ne.dll?bh0bkyd2
Hope it helps!
I left DHCP on dynamic even though my ISP changes the IP from time to time.
Cheers,
Tom Sisk
http://www.siskconsult.com
Tom, if I use the router's IP (instead of PINK's IP) how do I access pages on the PINK's server?
- Stephen
how do I distinguish the pink's IP from the router's IP. In the router do I assign the pink's IP when forwarding?
Shmow
Your router has 2 ip addys, 1 will be of the internal nature described above and it acts as a gateway, the other is your public IP addy assigned to you by your ISP. You can see what this is on your routers status screen page or a similiar page, most routers show the assigned addy somewhere. You can also hit a site like http://whatismyipaddress.com/· to get this public ip addy.
When you setup forwarding, you choose a port and addy to forward to, you should forward to the inetrnal ip addy that you can connect to on your lan, use port 80, the port PINK listens on.· So if your PINK is 192.168.1.101, you will use that as the forward to addy in your router. Now, when you try and access your public addy, the one you got above from whatismyipaddress.com, you should get to your PINK.
Remember, it is likely you won't be able to access your PINK using the public ip addy while inside your lan due to low end routers not supporting local loopback, it is also likely your ISP is blocking port 80, more and more block common ports like 80 these days. Get it configured and hit the shields up site I linked above to see if port 80 is open and not being blocked.
Then http://xx.xx.xx.xx:5800
Your WAN IP may be changing depending on who you have it with, so check that.
