full duplex serial questions and serial communication
i am·reading the book "making things talk", i am looking at the serial communication part that talks about handshaking·protocol, i would like to learn·more about this with the prop because i am looking at reading several sensors and stuff with multiple props. I was·wondering if the full duplex serial object has a serial buffer, and how often should i check it. my biggest·thing that i dont understand is how to know when to use a serial.rx command to read incoming data so that i·know data is coming in to the prop.·
There's also a 4 port serial driver in the Object Exchange ("Multiple Serial Port Driver"). Download it and have a look at the description in the comments. It has some provisions for automatic handshaking.
There are several receive calls like RX, RXCHECK, RXTIME. RXCHECK returns a -1 if there's no character available in the buffer (or the received character). RXTIME does the same thing, but waits up to a specified time (in milliseconds) before giving up.
the buffers of FullduplexSerial and FullduplexSerial are FIFO-Buffers. This means first in first out
Whenever a byte is sended to the propeller the byte will be stored in the receivebuffer.
If the buffer is full the oldest byte will be overwritten by the newest byte that comes in.
example
a 16 byte-buffer has received ABCDEFGHIJKLMNOP
and you did NOT read out the buffer yet.
now a "1" is sended to the prop
after receiving the "1" the buffer looks like this 1BCDEFGHIJKLMNOP
now a "2" is sended to the prop
after receiving the "2" the buffer looks like this 12CDEFGHIJKLMNOP
whenever you READOUT a byte from the buffer the buffer gets emptier
If you read out ONE byte by calling .rx the buffer contains still ABCDEFGHIJKLMNOP
but as you have readout the "A" there is one byte place for a new byte to receive
if a "1" is sended it is stored here 1BCDEFGHIJKLMNOP
but as you already read out the "A" it doesn't matter anymore that the "A" in the buffer gets overwritten by the "1"
You can experiment yourself with this if you add a method READOUT_rx_buffer to the Fullduplexserial-object
then send some bytes readout bytes by using READOUT_rx_buffer call .rx and read out bytes again by using READOUT_rx_buffer to see what changes are made to the buffer
If you don't know how to do that make a first try on your own or ask a concrete question here.
Concrete questions about a detail are MUCH easier to answer then global questions.
And to answer on concrete questions about a detail are MUCH MORE FUN than global questions.
best regards
Stefan
It actually is a circular buffer!
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
<insert aggregate>
