Reading info from BlinkM RGB LED
I am having trouble trying to read the I2C Address and firmware vesrion information from the BlinkM using a BS2. I have no problem sending commands - just reading. I have tried various combinations of instructions (based on code I use to access EEProms and a DS1307 real-time-clock).
Most of the examples I have found use the Arduino - the basic stamp examples I've found don't read data from the BlinkM.
Any help would be appreciated!
' {$STAMP BS2p} ' {$PBASIC 2.5} SDA PIN 0 ' I2C Serial Data Line SCL PIN 1 ' I2C Serial Clock Line DeviceAddr CON $09 '<< 1 Ack CON 0 ' acknowledge bit Nak CON 1 ' no ack bit I2C_data VAR Byte ' Work Byte For I2C I/O I2C_ack VAR Bit ' Ack Bit From Device BlinkM_cmd VAR Byte ' used by BlinkMSend & BlinkMSend3 BlinkM_dat1 VAR Byte ' used by BlinkMSend3 BlinkM_dat2 VAR Byte ' used by BlinkMSend3 BlinkM_dat3 VAR Byte ' used by BlinkMSend3 hueNum VAR Byte scriptno VAR Byte Main: DEBUG "Welcome to BlinkMTest", CR DEBUG DEC ? DeviceAddr, CR BlinkM_cmd = "o" ' stop playing boot script, e.g. "{'o'}" GOSUB BlinkMCmd 'GOSUB BlinkMVersion GOSUB BlinkMAddress BlinkM_cmd = "f" ' fade speed BlinkM_dat1 = 240 GOSUB BlinkMCmd1 BlinkM_cmd = "t" ' time adjust BlinkM_dat1 = 0 GOSUB BlinkMCmd1 BlinkM_cmd = "p" ' play black script, e.g. "{'p',2,0,0}" BlinkM_dat1 = 9 BlinkM_dat2 = 0 BlinkM_dat3 = 0 GOSUB BlinkMCmd3 BlinkM_cmd = "p" ' play script to HSB command, e.g. "{'p', script#, repeat, line#}" BlinkM_dat2 = 0 ' play forever BlinkM_dat3 = 0 ' line 0 MainLoop: 'DEBUG CR,"Enter a hue number (1-9): " 'DEBUGIN DEC1 hueNum ' read from the serial debug input 'hueNum = hueNum * 28 ' scale to hue range of 0-255 (approximately) 'BlinkM_dat1 = hueNum ' set the hue DEBUG CR,"Enter a script number (0-18): " DEBUGIN DEC2 scriptno ' read from the serial debug input BlinkM_dat1 = scriptno GOSUB BlinkMCmd3 GOTO MainLoop END '^^^^^^^^^^^^^^ BLINKM SUBROUTINES ^^^^^^^^^^^^^^ BlinkMCmd: 'DEBUG ASC ? BlinkM_Cmd, CR GOSUB I2C_Start I2C_data = DeviceAddr << 1 ' shift left because address is upper 7 bits GOSUB I2C_Send I2C_data = BlinkM_cmd GOSUB I2C_Send GOSUB I2C_Stop PAUSE 1 RETURN BlinkMCmd1: GOSUB I2C_Start I2C_data = DeviceAddr << 1 ' shift left because address is upper 7 bits GOSUB I2C_Send I2C_data = BlinkM_cmd GOSUB I2C_Send I2C_data = BlinkM_dat1 GOSUB I2C_Send GOSUB I2C_Stop PAUSE 1 RETURN BlinkMCmd3: GOSUB I2C_Start I2C_data = DeviceAddr << 1 ' shift left because address is upper 7 bits GOSUB I2C_Send I2C_data = BlinkM_cmd GOSUB I2C_Send I2C_data = BlinkM_dat1 GOSUB I2C_Send I2C_data = BlinkM_dat2 GOSUB I2C_Send I2C_data = BlinkM_dat3 GOSUB I2C_Send GOSUB I2C_Stop PAUSE 1 RETURN BlinkMVersion: 'doesn't work GOSUB I2C_Start I2C_data = DeviceAddr << 1 ' shift left because address is upper 7 bits GOSUB I2C_Send I2C_data = "Z" GOSUB I2C_Send SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]I2C_data\8] DEBUG "Version: ", DEC I2C_data, " - " SHIFTIN SDA, SCL, LSBFIRST, [noparse][[/noparse]I2C_data\8] DEBUG DEC I2C_data, CR GOSUB I2C_Stop PAUSE 1 RETURN BlinkMAddress: 'doesn't work GOSUB I2C_Start I2C_data = DeviceAddr << 1 ' shift left because address is upper 7 bits GOSUB I2C_Send I2C_data = "a" GOSUB I2C_Send ' GOSUB I2C_Stop GOSUB I2C_Start I2C_data = DeviceAddr << 1 ' shift left because address is upper 7 bits GOSUB I2C_Send IF (I2C_ack = Nak) THEN BlinkMAddress ' wait until not busy I2C_ack = Nak I2C_data = 0 ' SHIFTIN SDA, SCL, LSBFIRST, [noparse][[/noparse]I2C_data\8] SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]I2C_data\8] SHIFTOUT SDA, SCL, LSBFIRST, [noparse][[/noparse]I2C_ack\1] ' send ack or nak DEBUG "Address: ", DEC I2C_data, CR GOSUB I2C_Stop PAUSE 1 RETURN 'Send Address or Data Procedure I2C_Send: SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]I2C_data] '[noparse][[/noparse]I2C_data\8] 'Send Byte To Device SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]I2C_ack\1] '[noparse][[/noparse]I2C_ack\1] ' Get Acknowledge Bit RETURN ' -----[noparse][[/noparse] Low Level I2C Subroutines]---------------------------------------- I2C_Start: ' I2C Start Bit Sequence INPUT SDA INPUT SCL LOW SDA ' SDA --> Low While SCL High RETURN I2C_Stop: ' I2C Stop Bit Sequence LOW SDA INPUT SCL INPUT SDA ' SDA --> High While SCL High RETURN
- Stephen
The datasheet isn't much help since it caters to Arduino example code:
http://thingm.com/fileadmin/thingm/downloads/BlinkM_datasheet.pdf
