welders and cell phones
so, my dad had his second cell phone die in less than a year from getting his cell phone. He says hes not clumsy with it, but the problems are usually electric. The first failure was due to parts not working internally, and this last one was the phone not reading the battery. Is there any possibillity that it was caused from him welding all day close to his pockets or him just being really unlucky. Us other 3 have had absolutelly no problems. Any Ideas??
Does he put the phone down on the welding table or the welder??? We would need so much more information
I did reconstructive bookkeeping for a plumber for a while until I learned the previous bookkeeper quit due to the welding in the shop wiping out all the accounting data and backups on the computer. There was no way to sustain a computerized bookkeeping system unless he did some major protection. Things may be different now as that was years ago. But the cell phone is likely trying to interpret the EMF as intelligent traffic and getting zapped in the process.
So I guess he should just work around the realities.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
I use to weld all the time with my cell phone in my shirt pocket. I never had one fail from doing this. The problem I had was metal shavings getting into the speaker and causing sever distorting. I never could get all the shavings out because of the strong little magnets used to make the small speaker.
I have wiped out some ATM cards though. Looking through wallet can't find card, oh here it is in my shirt pocket. Swipe it "Card read ERROR". I degaussed the magnetic strip on the card from welding.
____________$WMc%_________
The Truth is out there············································ BoogerWoods, FL. USA
The welding machines are old oil filled transformer models and they weld mostly 50 mm (2 inch) and 75 mm square and rectangular tubing with a 1.8mm wall thickness (a bit thicker than 1/16 inch).
