Help!boe-bot whiskers code — Parallax Forums
despinadespina Posts: 1
edited 2009-06-23 18:39 in Robotics
I need a program in basic stamp 2 for boe-bot whiskers until tomorrow. Something different from the book for a homework and i don t know what. If there is somebody who has a program please help me.
Thanks all!
  • GWJaxGWJax Posts: 267
    edited 2009-06-23 18:09
    Just program a routine just like you would with a switch. There nothing different from the whiskers as to a push switch, now if you set up the contacts for the whiskers so each side has 2 switch modes, say if your backing up an the whisker hits the wall pulling it forward this would send a signal for that function to move forward and turn to release it. Then if you hit it straight on of course back up and turn.
    As for doing your homework for you, you'll learn nothing by members just writing it for you or handing over what they have done. So what I'm telling you is to reread the book and just do your best. This is how you become a great programmer in robotics.
    good luck,
    Jax
    If a robot has a screw then it must be romoved and hacked into..
  • P!-RoP!-Ro Posts: 1,189
    Just take it slowly and it won't seem so hard. What I advise doing to make this easier for you is to look on the parallax website for code snippets like a whisker program and combine it with code to run the servos. Then, if you are still having trouble, post what code you have and we will help you.
    PG
    Post Edited (Pi Guy) : 6/24/2009 5:26:14 AM GMT
