Opto Isolation
Hello,
I am looking to Optically isolate my BS2 from a limit switch and I was wondering if anyone could advise me on an Opto Isolator to use?
Kind Regards
Shaun
Kind Regards
Shaun
Just don't forget to limit the current to the LED portion of the opto-isolator.
Cheers
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Kind Regards
Shaun
Give us a bit of a schematic of what you're trying to do.
Cheers,
Tom Sisk
http://www.siskconsult.com
If so, the one suggested by others will work fine, but you need additional circuitry.
The "output" side of the isolator is usually tied to the base of a MOSFET, FET or transistor that will handle the desired current. That way, low current, 5 volts, is used to control a solid state device that has the current capacity you need. Is this what you are asking?
Richard Vannoy
Programming and Electronics Instructor
www.RichardVannoy.info
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I am connecting the basic stamp 2 to a modem. The modems maximum output current is 3A.
I am not 100% sure how an opto isolator works but i was looking for a way to isolate the stamp from the modem just incase it runs its max output current and blows the stamp. Anyone got any advice on how to use the opto isolator?
Cheers
Shaun
Leon
If anyone has an OPTO-ISO that draws less than 15mA at 5vDC on the control side, and can swicth 120vAC at 2 to 3 amps on the working side. Please post it.
Thanks in advance!
______$WMc%__________
The Truth is out there············································ BoogerWoods, FL. USA
