Wrong Zeners from factory?
I have attached my circuit to the mcp3208. I have verified that these zeners are clamping the voltage around 2.8 - 2.9 volts. The zeners are 3.9v
Zeners D11-D13 www.fairchildsemi.com/ds/MM/MM5Z3V9.pdf
Diode D6, D9, D10 www.semiconductors.com/acrobat/datasheets/PMEG3002AEB_1.pdf
This seems odd. I have verifed the number 55 printed on the zeners.
pdf
46K
Post corrected: "aren't", not "are".
Post Edited (Phil Pilgrim (PhiPi)) : 6/23/2009 3:37:44 PM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
A "perfect" zener diode would have a vertical line at each rated voltage. But, as you can see, real devices are far from perfect.
As you see from the graphs Phil just posted, low voltage zeners have a particularly "soft" knee, so at microamp current levels the voltage will be the 2.8 volts you observed, and conversely, even when the input voltage is low, these diodes will be drawing a small current and dropping a voltage (=error) across the resistors R27-R29.
You are using these for input protection. A more usual scheme is to tie the (+) side diodes to the Vdd power supply, so that fault currents are shunted there when the input voltage exceeds Vdd by one diode drop, same as you have on your schematic for the (-) side in relation to Vss.
I use a protection array like the SP721. It is a single chip that has six protection circuits for both (+) and (-) fault protection.
How are the isolation amplifiers working out?
Tracy Allen
www.emesystems.com
@leon .The resistor coming from the isolation amp is a 3k resistor. I am expecting input voltages from 0 - 3 volts.
@Tracey . I am happy with these op amps. My first test was with these at 100 gain, and they are quite stable. So far it looks like they are going to work out well with those galvanic sensors, and they seem to be more stable than the competitors boxes input.
Thanks all, I had not realized low v zeners had that kind of knee.
Tracy Allen
www.emesystems.com
Tracy Allen
www.emesystems.com
