Using a Parallax Basic Stamp over 15000 feet ( over 4000 meters)
Hi
I need to acquire temperature over 15000 feet.
Sometimes at this altitude some components like
condensers, resistors, etc. my exploit.
Do you know if a Basic Stamp could work at this altitude ?
Thanks, Markus
PS: Do you know if the propeller does?
Thanks, Markus
Post Edited (Mike Green) : 6/23/2009 4:13:56 AM GMT
humanoido
Information about altitude is difficult to find.
But it is important to know . Do you know if Parallax has
this information about Basic Stamps? Something like "Key Specifications" ?
Like temperature, the altitude is very important to know.
In fact, instead altitude, the name could be something like "minimum pressure".
Perhaps the information about sounding rockets and balloons could be useful.
Do you know where can I find these information ?
Thanks, Mark.
You could try it yourself. Make a pressure chamber with a wire coming out. Drop it to vacuum and see if the BS2 can still transmit serial data.
Paul Verhage has done extensive work in Near Space with the BS2p, and in fact wrote a book about it. It is posted by chapter on our website here:
http://www.parallax.com/Resources/ApplicationsContests/Science/NearSpace/tabid/567/Default.aspx
If you meant to say "may explode", I really don't believe that is an issue. If something were assembled and sealed at sea level and then launched into the near vacuum of space, there would be less than a 15 psi pressure differential. When applied to the tiny area of a chip or other component the outward force would be measured in fractions of an ounce. I haven't done the math but I would suspect bigger internal pressure problems right here on the ground when things get close to overheating.
This same type of "things exploding in space" issue came up regarding the space shuttles tires and why they didn't explode. I don't know what pressure the shuttle's tires run at, well over 100 psi I am sure, 15 psi extra when in space is nothing compared to the extra pressure they will get when they heat up upon landing.
Rich H
At 15k ft, you're probably not going to be too worried about temperature (depending on your location). Most stamps are rated to 32F (0C), but the industrial BS2 can go down to -40C. If you are expecting to get into a region of the atmosphere where temperatures may drop below freezing, better play it safe and use a stamp or prop that is rated down to at least -40C.
Hope that helps,
Dave
On the temperature side, I have had standard BS2s down to -55 Celsius in an environmental chamber, operating without problem. The BS2e and BS2sx now I think come standard in industrial temperature range. The BS2pe and BS2p can have problems at sub sub zero temperatures, although the OWL2pe and the MOBO Stamp (both BS2pe based) have different settings and are okay down below -40 Celsius.
Tracy Allen
www.emesystems.com
