Voltage problem
Hello,
I have been trying to divide a voltage from an LC circuit. The attached circuit shows a working circuit. At test point T2, It measure 5 V AC. My question is I am want the diode to rectify the AC into DC so I can send it to a ADC0831. If I put the diode before the 10 M resistor it does, but my voltage is almost zero at the divider junction. Any suggestions would be appreciated.
Thank you,
Cenlasoft
Thank you,
Cenlasoft
An opamp at the initial stage should allow you to source more current to a voltage divider so that you can measure it.
I'd use a parallel resonant circuit with the diode connected to a tap on the inductor, or a link winding, to prevent it loading the circuit too much.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
*Peter*
P.S. darn, I see some other replies now, same thing, that's what happens when work interrupts you!
Cenlasoft
Cenlasoft
I tried replacing R3 with various small caps connected to ground. No change. I going to have take a different approach. Maybe I can analyze the AC signal instead of converting to DC.
Cenlasoft
The loading at T2 lookiing into the ADC0831 should be a very high resistance.
Why? As the voltage on the capacitor charges up to the peak level of the sine wave, the diode impedance increases exponentially and ceases to load the resonant circuit, except for the leakage through R3 and the input impedance of the ADC0831. The forward voltage drop of a 1N4148 at 0.5 microAmp average current at equilibrium would be around 0.3 volt. The response time will be set roughly by the parallel combination of R3 and its parallel capacitor. Say 10 MOhm || 0.01 uF => 0.1 second. That circuit should not substantially load down the resonant circuit, except briefly when the input level makes a step increase.
Tracy Allen
www.emesystems.com
Thanks Tracy. I'll try that tonight. Your explainations are great. My students will be happy if it works.
Cenlasoft
