Motor mount kit voltage question
Hi an thanks for a great forum at Parallax!
I recently ordered the "Motor Mount Kit", which has 12V motors.
I have a battery pack with 14.4V. Can I put this directly to the kit or do I need a voltage divider. If I need a voltage divider, what resistors should I use?
Sounds like your plan is to just switch the motors on & off, perhaps with simple transistor switches or relays. They'll work, and shouldn't burn up at 14 volts, but you'll find out pretty quickly that on/off switching is not useful for any precision motor control for maneuvering. If that's your goal, you'll end up springing for a PWM motor speed controller pretty quickly, so add that to your budget.
Post Edited (erco) : 6/22/2009 12:59:19 AM GMT
