I wish to build a Neurobot or Brain Based Device (BBD)
One of my goals from the beginning is to build a sort of poor man's BBD or Neurobot. Most of the units out there are relying on Beowulf technologies. But, I am not giving up. If any of you have experience or know something about the subject, I am a noobie in this new field. I always knew what I wanted, but I did not know what it was called.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Thanks for the Reply.
Post Edited (MovieMaker) : 6/20/2009 7:38:14 PM GMT
The first thing you should consider is advancing your IQ to sub-rocket-scientist, or invest heavily in medications, before you begin. [noparse]:)[/noparse]
Beowolf clusters are going to fade out, I think, because of the rise in power and the extreme reduction in costs of using GPU's (Graphics Processing Units). You might want to consider looking into the Nvidia cards built on their very powerful GPU's. Look for the ones that support the CUDA development platform. The one I've got in this machine can support 12,000 simultaneous threads - and barely break out into a sweat. Other Linux distributions to consider are "Pelican" (formerly Parallel Knoppix) and Quantian (aslo a Knoppix/Debian derivative, if I recall correctly.)
I guess it's obvious that you'd like to try some of these techniques on an MC, not a PC, so your options will be limited. Sophisticated neural nets require serious memory management and multi-processes. (Thus the clusters.)
That said, there is an interesting alternative to consider, if you need neural net-like control abilities, without the overhead: fuzzy logic, and generally, PID controllers (Proportional–Integral–Derivative). If you do Propellers, you might want to take a look at Viewport. Hanno Sander wrote this, and has cool sample code for landing on the moon using fuzzy logic. That PID brain is better than my protein brain for landing!
- Howard
That said, if you are serious these books are a place to start:
Neural and Fuzzy Logic Control of Drives and Power Systems by Cirstea, MN, A Dinu, JG Khor, and M McCormick. Warning it runs about $70.00 used and they use FPGA's for their Neural-Fuzzy chips.
The Fuzzy Systems Handbook(With C++ code examples) by Cox. You can find it used cheap and is a good intro/tutorial on FL.
Jax
If a robot has a screw then it must be romoved and hacked into..
Sorry not this one.. This was only for MovieMaker. I'll see if I can come up with something else..
Jax
self aware, and self deterministic, complete with a short
term or long term memory, and some purpose in life, then
keep an eye out for SEED, the details are posted in the
Project Forum and periodically updated, link below. In its
entirety, it will fit into the smallest amount of EEPROM code.
It has a tentative 7 Phase code with the 2nd currently in
progress. Part of SEED is Minscule AI - an interpreter
that was developed for my Basic Stamps and Toddler
Humanoid.
humanoido
Stamp SEED Supercomputer
Basic Stamp Supercomputer
Three Dimensional Computer
Penguin with 12 Brains
Penguin Tech
StampOne News!
Penguin Robot Society
The best metaphor I can think of in wetware would be a ganglion... not an actual brain (in such a small machine). People have already mapped the entire neural circuits of simpler worms and snail type things. What they discovered was that a lot of processing happens 'on the way' to the brain. There are all sorts of reflex, feedback, filtering and decision making calculations that go on way before any stimulus gets sent to the CNS.
So, with neural network source code being readily available on the web, it's not a stretch to make a little ganglion. And here's the thing... higher order behaviors can arise from lots of little stupid decisions-- even reflex. That is entertainment. And that, after all, is why we do these things. Right?
And by the way, humanoido... I can't believe you made a Basic Stamp supercomputer. You're nuts!
yes, this is interesting - a fly's eyes for example are tightly coupled to its leg and wing muscles. And they nearly always jump backwards in take off (so now you know how to nail them without a fly swatter [noparse]:)[/noparse]
Otter, it would be fun to have your 'ganglion gadget' hooked to a sensor and some muscle wire ...
