Regarding SMART mode of parallax GPS
I am using Parallax GPS module. Its RAW mode works fine, but I am unable to work with SMART mode, the problem being the GPS Module has only single pin for serial communication named as SIO, while my microcontroller or any such device has two separate pins for serial communication. So what will be the schematic of it?
Moreover I am unable to understand the format of the command to be sent in SMART mode. Can anybody plz suggest me thru one example?
plz its very urgent...
http://forums.parallax.com/showthread.php?p=791719
If you understand java you should have no trouble understanding it.
regards peter
Parallax Engineering
Two pins: o----RxPin---+----GpsPin---o | [noparse][[/noparse]1k ohm resistor] | o----TxPin---+ In this case there are seperate receive uart and transmit uart and anything sent is directly received (local echo)regards peter
you must filter this echo out.
Either stop the receiver before transmitting, or clear
the receive buffer directly after finishing transmitting.
regards peter
Without the resistor the TX line of your MCU would be directly driving against the GPS line when it was transmitting data. You could have a direct short without it.
