Is it possible to use controls to Set power Out put?
Hi I am currently working on a project that requires power from an analog Controller to a motor. What I'm currently trying to develop is how much power is used from the pressure of the analog Controller to the motor Another words, if I press the controller 50% then the output power will be 50% If i press it all the way down It will output 100% Power to the Electric Motor
The harder you press, you lower the resistance. If you release the pressure, resistance rises.
It just looks like a black cuboid of material, but if you place it on a metal foil and press a wire to the other side as you press, it works.
Very cheap, very easy to use.
www.eleinmec.com/shop_category.asp?1389-quantum-tunnelling-composite
Morrolan
Flying is simple. You just throw yourself at the ground and miss.
"I think computer viruses should count as life. I think it says something about human nature that the only form of life we have created so far is purely destructive. We've created life in our own image."
Stephen Hawking
