Successful communication using the 3-Transistor adapter!
Hello everyone,
I was not able to get my 2-transistor serial adapter to work with the propeller, but I headed over to radioshack and picked up a 2N3904 transistor and made the 3 transistor version. It works perfectly! on the first try after 15 minutes of building the circuit, I had a working propeller. I am so happy!
I uploaded a video of the blinking LED program running on the chip.
www.youtube.com/watch?v=x5OZ2iO_PFo
here's a pic:
Brandon C.
No purchase necessary. See back panel for more details.
here's a pic:
Brandon C.
Nyamekye,
Wish someone would do blank PCB's for that circuit.
Would be a nice option for budget propellerheads.
OBC
New to the Propeller?
I can make and sell the boards, but I cannot guarantee they will work.
Las - Large model assembler for the Propeller (alpha version released)
Largos - a feature full nano operating system for the Propeller
www.mikronauts.com - a new blog about microcontrollers
USB to RS232 converters just can not be relied upon to give correct handshakes, and so give DTR for the reset.
Style and grace : Nil point
That's really cool!
If it could be made to work reliably even with the USB to rs232 adapter it would be a great circuit to
add to a project board
I could sure use a good circuit like this...I just know I'm going to lose every proplug thing we buy, they are sooo tiny!
(I'm thinking of using epoxy glue to affix a USB cable permanently so I don't lose them)
adapters with a prolific-chip do NOT work reliably with the propeller
FTDI-chips DO work reliable with the propeller
best regards
Stefan
@OldBitCollector
I would make some blank PCB's and sell them but as others have said they aren't very reliable. I would not like for someone to be disappointed if the circuit did not work.
Brandon C.
Talking about pcbs, here it is. I made these up as I got sick of throwing transistors together. Even though they are smd they are very easy to assemble as you only need a normal soldering iron.
*Peter*
Peter Jakacki darn that's small can you solder that yourself ???? is it all SMT??? very nice by the way I have a pretty nice iron a few of them actually and mine always gets glazed over when I am using them thenb the solder will not melt and I end up getting a big glop
and its a mess even if I wipe the iron a lot when using it I can not imagine doing SMT , do you use a low heat iron?? mine is variable but I crank it to 480
Post Edited (mikediv) : 6/19/2009 10:58:16 PM GMT
My
Gosh
I have pondered over my three transistor circuit for sooo long now...
I feel like hiding in a corner and trying to fix my SD card adapter...
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
Brandon C.
Right now back to using a PC and a CPLD to emulate some TTL, Hey-Ho.
Everyone should know, that the only reason the 3-transistor circuit exists is because I managed to come back from California without my PropPlug and I was desperate to get things going. No, it's not a perfect circuit, and I borrowed much of the design from a tried and true circuit that is currently used in the BS2 modules. The reason that some USB to RS-232 adaptors don't function is because the 3-transistor circuit really "expects" RS232 levels and the USB to RS-232 adapters generally don't provide that. Now, you might get lucky on the 3-transistor circuit and choose your transistors that happen to have a really high Hfe and it will work at the lower level voltages, but the 3-transistor circuit is really looking to be plugged into a PC "with" a real COM port. Additionally some USB to RS-232 adapters do not properly bring out the DTR line which can cause the IDE to not recognize the Propeller properly.
Beau Schwabe
IC Layout Engineer
Have the two transistor working. Found it in a parallax manual. Looked good so built it and it work. Connector is a bit loose but works with std RS232 and a cheep USB to RS232 ( Prolific USB-to-Serial Bridge ). Was in a hurry so used two .05 instead of a .1 as the original circuit called for.
If you don't mind what is the diagram for three? Be interesting to try it...
Here is the one I cooked up... With USB adapter connected... Click on pix for bigger versions...
Top View:
