New to the BS2p24 - one wire woes.
I'm looking for some guidance.
I have a part labeled DS1820. I've tried the code from the BS2P section of the BASIC STAMP EDITOR for owin owout examples... and I just get:
DS1822
10 C
50 F
No matter what.
I've verified that the Stamp finds the ROM ID with other methods (code samples from the forums) and the BS2p24 gets the right ID: 10 A5 C5 54 01 08 00 B7, but looking at the scratchpad after a temperature conversion command always returns the following 16 BIT values LSbyte: FF MSByte: 00. ALWAYS.
I'm stumped... Ive tried lots of code from the forums that seems to work for others... and I've tried multiple DS1820's. I know they work because they are fine in my weather station. I'm not going to trudge off to write my own code from scratch till I see it work once... make sense?
The BS2P24 just doesn't like my devices?
They are parasitic (DQ has a 4.7K resistor to STAMP Vdd and the GND and Vdd pins are tied together to enable parasitic mode on the sensor)
There's nothing like a new idea and a warm soldering iron.
DS1822
10 C
50 F
No matter what.
Dave
Dave Andreae
Parallax Tech Support·
Tracy Allen
www.emesystems.com
Shawn Lowe
When all else fails.....procrastinate!
It relies on infrequent polling of the device and stores energy in the cap while the I/O line is pulled high. When the line is low, the diode blocks, keeping the cap from draining into the I/O line. The cap will have to be big enough to provide adequate hold-up time while the device is drawing its active current. This needs to be offset by the required charge time through the pullup resistor. A slightly stiffer pullup at the Stamp end may help in this regard.
Ultimately, I plan to use the STAMP with my Dallas 1-wire weather unit, so if this modification works... it would make moving forward easier with the rest of the devices.
I thought the 1-wire bus stays high with no data... data pulls it low... so if I DON'T write... it will charge the cap...right?
...or do I understand that wrong?
Post Edited (pwillard) : 6/19/2009 1:51:51 AM GMT
But a while ago I was trying to get the sensor connected to a BS2, and after posting and searching I found this:
http://www.beescollc.com/MBENZ/MBSENSOR.htm
At the bottom of the page there is a link for his design. Got in contact with the gentlemen and sure enough, I need better than a BS2 (soon to purchase a BS2P)
and a 1 wire won't work.
Just to let you know !
Cheers
