Basic stamp & Linux: how to read data on serial port?
Dear forum,
I know this question has been raised several times but I haven't found the answer.
I have a quite extensive experience with Linux/POSIX C API for serial communication (tio, read, write and so on) but I'm a newbie to Basic Stamp. Despite my efforts I have not succeeded in communicating with my BS2e in C under Linux.
I would like to read data from a CMP03 device (connected via I2C) on the PC .
The PBASIC program seems OK (it runs under windows with Parallax soft). By the way it doesn't work with Hyper Terminal under windows so I guess it's a matter of serial port configuration.
The program waits for a 'j' and then outputs the bearing followed by CR ('\r' in C).
The basic stamp is plugged under /dev/ttyUSB0 (permissions are OK).
I have configured the tio to use baudrate 9600 and 8N1.
Writing 'j' on the port seems ok but I can't read data. My best trials returned 'j' (the very same things that I have input).
Questions:
1) Do I need to do disable/enable the DTR and RTS bits? Those seems to be disabled by Stamp Editor.
2) Can I use the canonical mode?
3) The documentation of SERIN and SEROUT talks about INVERTED polarity. What's this?
I must confess I'm a bit lost. Any help would be appreciated. Thanks in advance.
Mathieu
'{$STAMP BS2} '*********************************************************** '** ** '** I2C Routines for the Basic Stamp ** '** using the CMPS01 Compass Module ** '** ** '** Copyright 2002 - Devantech Ltd ** '** Commercial use of this software is prohibited ** '** Private and educational use only is permitted ** '** ** '** Written by Gerald Coe - January 2002 ** '** ** '** This Code has been Tested on BS2 and BS2p ** '** It should work equally well on the BS2e and BS2sx ** '** ** '** E.T.I.S Neurocybernetic 10/2004 ** '** Modified by N.Cuperlier for the Blue Robot ** '** ** '*********************************************************** SDA con 8 ' I2C data SCL con 9 ' I2C clock SDAin var in8 SDAout var out8 SDAdir var dir8 loop var byte ' just a looping counter I2cBuf var byte ' I2c read/write buffer I2cAddr var byte ' Address of I2C device I2cReg var byte ' Register number within I2C device I2cData var word ' Data to read/write I2cAck var bit ' Acknowledge bit Main: '** wait for an serial input "J" to send back the value of the compass ' debug 1,0,0, "Entrez J pour lire la valeur de la boussole" serin 16,16468,[noparse][[/noparse]WAIT("j")] ' I2cAddr = $c0 ' CMPS01 Compass module address I2cReg = 1 ' Bearing as 0-255 (BRAD) gosub I2cByteRead '**debug 2,0,0, "Compass Bearing (0-255 BRAD) ", dec3 I2cData I2cReg = 2 ' Bearing as 0-359.9 degrees gosub I2cWordRead '**debug 2,0,1, "Compass Bearing (0-359 Degrees ", dec3 I2cData/10 serout 16,16468,[noparse][[/noparse]DEC I2cData/10, CR] goto Main Baddata: 'debug 1,0,0, "wait:",CR sleep 2 goto Main I2cByteWrite: ' writes I2cData.lowbyte to I2cReg at I2cAddr gosub I2cStart I2cBuf = I2cAddr gosub I2cOutByte ' send device address I2cBuf = I2cReg gosub I2cOutByte ' send register number I2cBuf = I2cData.lowbyte gosub I2cOutByte ' send the data gosub I2cStop return I2cWordWrite: ' writes I2cData to I2cReg at I2cAddr gosub I2cStart I2cBuf = I2cAddr gosub I2cOutByte ' send device address I2cBuf = I2cReg gosub I2cOutByte ' send register number I2cBuf = I2cData.highbyte gosub I2cOutByte ' send the data - high byte I2cBuf = I2cData.lowbyte gosub I2cOutByte ' send the data - low byte gosub I2cStop return I2CByteRead: gosub I2cStart I2cBuf = I2cAddr gosub I2cOutByte ' send device address I2cBuf = I2cReg gosub I2cOutByte ' send register number gosub I2cStart ' repeated start I2cBuf = I2cAddr | 1 gosub I2cOutByte ' send device address (with read set) I2cAck = 0 ' send Nak gosub I2cInByte I2cData.lowbyte = I2cBuf ' read the data I2cData.highbyte = 0 gosub I2cStop return I2CWordRead: gosub I2cStart I2cBuf = I2cAddr gosub I2cOutByte ' send device address I2cBuf = I2cReg gosub I2cOutByte ' send register number gosub I2cStart ' repeated start I2cBuf = I2cAddr | 1 I2cAck = 1 ' send Ack gosub I2cOutByte ' send device address (with read set) gosub I2cInByte I2cData.highbyte = I2cBuf ' read the data I2cAck = 0 ' send Nak gosub I2cInByte I2cData.lowbyte = I2cBuf gosub I2cStop return I2cOutByte: shiftout SDA, SCL, MSBFIRST, [noparse][[/noparse]I2cBuf] input SDA high SCL ' clock in the ack' bit low SCL return I2cInByte: shiftin SDA, SCL, MSBPRE, [noparse][[/noparse]I2cBuf] SDAout = 0 SDAdir = I2cAck high SCL ' clock out the ack' bit low SCL input SDA return I2cStart ' I2C start bit sequence high SDA high SCL low SDA low SCL return I2cStop: ' I2C stop bit sequence low SDA high SCL high SDA return
Questions:
Mathieu
First I have used C code to reset the basic stamp (thanks to open source) by playing with ioctl().
Second I have slightly modified the code to insert a pause after the SEROUT command and an explicit message after initialization.
All in all this seems to work. If somebody have a better way to do I'm still opened...
Mathieu
