Need Help on the GPS receiver module ( Parallax ) — Parallax Forums
havenganhavengan Posts: 4
edited 2009-07-08 17:06 in General Discussion
Hi guys, I've this problem whereby when I dl the Demo code from the Parallax website and use it on Basic Stamp 2. It keeps on giving me garbage results. Does anyone know how can I fix the problem? fyi, these are the code which i use :
http://www.parallax.com/Portals/0/Do...PSDemoV1.1.zip
    edited 2009-06-17 16:53
    This can happen if the GPS Module is sending out data in RAW mode. Can you check the level of the RAW pin? It should be high. If no, that could be your problem. Which BASIC Stamp model are you using?
    Parallax Engineering
  • havenganhavengan Posts: 4
    edited 2009-06-24 00:32
    i am using Basic Stamp 2p
    edited 2009-06-24 15:54
    Okay well that explains it then. That program was written for the BS2. The BS2p uses different values for the baud rate timing. You can modify the program to use the correct values for the BS2p. The values can be found in the BASIC Stamp Manual or Help File. I hope this helps. Take care.
    edited 2009-07-08 01:37
    so how can we do about it??
