serial port communication question
Hi All,
Noticed something odd tonight during my experiments in setting up serial port communication from a BS2 and VB2005 program.
First - the BS2 is running a loop where it does a SEROUT at 2400 baud 8NP <text> and then does a SERIN at 2400 baud 8NP waiting for a DEC with a time out of 3 seconds.·The code tokenizes, downloads, and runs with no errors.
Second - HyperTerm has been configured for 2400 baud 8NP, and when connected to COM4 (the BS2 via a Parallax Serial to USB converter), the text from from the SEROUT is recognized properly; a number can be entered and recognized by the BS2.
All is well at this point.
Where the confusion arises is when I run a VB2005 app that reads the available COM ports, the baud rate is always 9600 even for COM4 that the BS2 is using.· I would think I'd read back 2400 as that's the SEROUT setting.
Anybody have any ideas?· Maybe I'm continually reading the baud rate characteristic from one COM port only...
DJ
Instead of:
"Those who can, do.· Those who can't, teach." (Shaw)
I prefer:
"Those who know, do.· Those who understand, teach." (Aristotle)
DJ
Instead of:
I prefer:
I expect Unsoundcode will have a more definitive analysis of the issue with VB.
Cheers,
Tom Sisk
http://www.siskconsult.com
When communicating with a serial port you have set the baudrate property before you try opening the port.
I hope I understood the problem.
Jeff T.
OK - I'm obviously missing something here as I have no experience in serial communication between a BS2 and a VB2005 app.
Do I really have to set up the serial port characteristics prior to opening it?!?! Is there no way I can just say "hey COM4, what's your baud rate?"
DJ
Instead of:
I prefer:
I have never tried either but did once see an example in C# of the latter.
You could try googling it , if you find a VB example and need help adapting it for your needs let me know.
Jeff T.
DJ
Instead of:
I prefer:
