Constant folding
I've just seen the Parallax compiler fold a constant and I can't figure out why it would do it here and never previously.
The code in question is in the Parallax Examples :
(Ch3-Ex12)-RealNumbers
Its the last line in the file and it's entirely constants.
Term.Dec(trunc(B*K)*trunc(C*K)/trunc(D*K))
The code generated is this :
Yet this code further up
Term.Dec(iB*iC/iD)
Generates the following :
Each piece of code is working on constants defined in the CON section.
To say I'm baffled is putting it very mildly! This is the first time I've ever seen it fold a constant. (scratches head)
On another note, this example has exposed a gross hole in the bst[noparse][[/noparse]c] compilers with regard to the ROUND() and TRUNC() operators that none of my previous tests have exposed.
This is the only file in all Parallax supplied spin that triggers the bug. None of the Hydra or Obex source triggers it either, but please be aware.
Will not work with any published versions of the compiler. (It does not emit bytecode for the value generated by TRUNC() - Obviously not a common construct as I've never hit it before)
Eccles : How do I open the door?
Bluebottle : You turn the knob on your side
Eccles : I haven't got a knob on my side!
0:1 : 007A : 39 09 34 : Constant 2 Bytes - 09 34 0:1 : 007D : 06 02 05 : Call Obj.Sub 2 5 0:1 : 0080 : 32 : Return
Term.Dec(iB*iC/iD)
0:1 : 0031 : 01 : Drop Anchor 0:1 : 0032 : 39 02 F8 : Constant 2 Bytes - 02 F8 0:1 : 0035 : 39 0F 23 : Constant 2 Bytes - 0F 23 0:1 : 0038 : F4 : Math Op * 0:1 : 0039 : 39 04 E2 : Constant 2 Bytes - 04 E2 0:1 : 003C : F6 : Math Op / 0:1 : 003D : 06 02 05 : Call Obj.Sub 2 5
CON A = 123.456 B = 234.567 PUB ABCD | X X := trunc(A*B)
